Mitsubishi WD-62825 62 in. Rear Projection HDTV Television
Problems with Mitsubishi WD-62825 62 in. Rear Projection HDTV...?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Mitsubishi WD-62825 62 in. Rear...
Troubleshooting and Support
Solved Problems for Mitsubishi WD-62825 62 in. Rear Projection HDTV Television RSS Feed
View More Results for Mitsubishi WD-62825 62 in. Rear Projection HDTV Television
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WD-62825 62 in. Rear Projection HDTV Television RSS Feed
Answer
Have no input signal from the satellite box. Switched boxes, no change. Can watch DVDs on the screen... (More)
Answer
About a year ago, the main chassis went out (was getting bad picture). Since Mits stop making the... (More)
Answer
tv turns off after watching extended time, and I have to reset the tv never had this problem before
Answer
We cannot get the DM board off of the TV to replace the capacitors
Find a Manual
Mitsubishi WD-62825 62 in. Rear Projection HDTV Television Manuals & Guides
WikiManual
(Post a New Chapter)
Be the first to Post a New Chapter
Upload Manuals
Tips & How To Guides for the Mitsubishi WD-62825 62 in. Rear Projection HDTV...
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
Solution for Video looking whiteish, dull, or too red
Here are some of the most common symptoms and examples of a convergence problem. This is a very common failure on Projection TV sets. Screen looks 3D... written by Ecollier2012
Are lamps easy to install!
Are lamps easy to install? I think it is! And also it depends on what brand is your TV I have told people how to change it and they do... written by Angel Petter
How much will it be to replace my lamp?
How much will it be to replace my lamp? It all depends on the type of lamp and manufacturer u has, some brands are compatible that is... written by Angel Petter
When it's time to replace you TV lamp!
When it's time to replace you TV lamp! The screen will lose its brightness and depending and how much you use your TV. You can... written by Angel Petter
How long does a DLP lamp last?
How long does a DLP lamp last? The most DLP Television last in between 1000 and 2000 hours this is whit the original lamp and depending... written by Angel Petter
Buy a TV is like when you buy a car!
When you buy a TV is like when you buy a car. You are looking for the best @ the best price. And its exactly de same you need to give... written by Angel Petter
Mitusbishi shuts off instantly...
Most of the Mitsubishi rear projection sets made from about 2000 through 2006 have a self diagnostic check feature. It will indicate if there is a... written by SD Tech
Big Screen rear projection TV picture not showing
Had a problem with my Hitachi Big screen projection TV, TV would turn on but had no picture, didnt matter what input it was on, the DVD and... written by findpeace
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for Mitsubishi WD-62825 62 in. Rear Projection HDTV Television
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Featured Listing
Ratings for the
Specifications for Mitsubishi WD-62825 62 in. Rear Projection HDTV Television
Key Features
Screen Size
62 inch
Display Format
1080i (HDTV) · 480p (EDTV) · 720p (HDTV) · 480i (SDTV)
Digital TV Standard
HDTV
Projector Technology
DLP
Display Capabilities
Aspect Ratio
16:9 · 4:3 Enhanced
Built-in Tuner
NTSC · ATSC
Remote Control
Remote Control
Learning
Illuminated Remote
Illuminated
Image Quality
Comb Filter
3DYC / 3D Digital
Adjustable Color Temp.
With Adjustable Color Temperature
Audio Features
Audio Output
Fixed
Audio Type
Virtual Surround
Sound Leveler
With Audio Leveler
MTS Stereo
SAP / MTS Stereo
Secondary Audio Programming (SAP)
With SAP
Technical Features
Picture in Picture
With PIP
Parental Control
V-Chip
Sleep Timer
With Sleep Timer
Connectors
Rear Input Connectors
Audio (Mini Jack) x 1 · Component x 2 · S-Video x 2 · Composite x 2 · 1 x D-Sub (RGB PC) · RF x 2 · 1 x RS-232C · RGBHV (BNC) x 1 · HDMI x 1 · FireWire x 2 · Audio (RCA) x 7
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · S-Video x 1 · Firewire (IEEE 1394) x 1
Rear Output Connectors
Composite x 1 · Audio (RCA) x 2
Memory Card Slot
CompactFlash Card · SD Card · SmartMedia Card · MMC Card · Memory Stick
Screen Text
OSD Languages
English · Spanish
Channel Labels
With Channel Labels
Closed Caption on Mute
With Closed Caption On Mute
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
19.9 in.
Height
43.7 in.
Width
58.3 in.
Weight
165.5 lb.
Warranty
Overall Warranty
1 Year
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Projection... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
