20 Most Recent RCA RP5008 Handheld Digital Voice Recorder Questions & Answers
have you tried formatting it? press erase till it flashes delete, then press and hold record for 3 seconds till it says Format, then press and hold erase till it says wait..it should fix it if that's the problem
RCA RP5008... | Answered on Aug 29, 2010
The only way to unlock is to hold the menu button down for three seconds. This will lock or unlock the recorders functions.
RCA RP5008... | Answered on Dec 26, 2008
Contact RCA directly to inquire.
RCA Audio... | Answered on Jun 26, 2019
1. Look at the user manual, typical setups are described. If you don't have your manual anymore, the PDF will be on the Internet, you need the Brand and Model name of your TV.
2. HDMI *can* have an output, HDMI 1.4 supports "Audio return channel (ARC)" - where a digital audio channel sends the audio back from the TV (for soundbars etc.).
3. Yes, there are Coaxial to Optical converters, IF you need something like that.
RCA Audio... | Answered on Jun 11, 2019
How do I fix my YT-03 digital player the computer says it malfunction?
RCA Audio... | Answered on Jun 08, 2019
There is no phono input on unit. If you wish to use turntable you willl need to buy a quality preamp, and appropriate cables.
RCA Audio... | Answered on Jun 06, 2019
Stereo amplifies are just two mono ones joined together. So if you have a problem with the left you can always look at the right side if that is working good. As all the parts are the same and so are any voltage readings taken. A visual inspection is the first option, if something looks strange in the left channel compared to the right, then replace it with the same part you can see in the right. The only problem is when the amp uses one power amp for both channels. But in that case replace the thing.
Apart from that individual parts, such as the power supply, you can leave alone, as they would affect both channels.
RCA Audio... | Answered on May 09, 2019
Hello Melissa, if the predefined channels, you can not find them, because they have been deleted, you can retune them and memorize them, then you have the way to do it
Choosing A Radio Station
1. Choose the Tuner function. The system will default to the last station of the tuner was set to before power was
removed.
2. Use the BAND button to choose AM, FM 1 or 2.
3. Use the TUNING UP (+) or DOWN (-) button to select the radio station you want to hear.
• Pressing the +/- button once will move the tuner incrementally.
• Pressing and holding the +/- button will cause the tuner to automatically search for the next frequency
broadcasting clearly. "AUTO" will appear in the display.
4. Press the FM MODE button to switch between FM Stereo and FM Mono for better reception of FM stations. Be
aware, however, that you can only receive FM stations in stereo if they are being broadcast in stereo.
Programming presets
Your system is capable of holding up to 24 preset radio stations in memory (8 from FM1, 8 from FM 2 and 8 from AM)
for as long as the unit is plugged in, and up to two weeks after AC power has been removed.
1. Choose the radio station and band you want to store.
2. Press the MEMORY button to activate the Preset mode.
3. Select a preset number by using the PRESET UP () or DOWN () buttons to select the preset channel you want
to hear.
4. Press MEMORY again to lock in your choice.
After you have finished programming your selections into the system's memory, you need only use the PRESET UP or
DOWN buttons on the unit to search for the desired frequency. On the remote, use the number pad to select the
number of the preset channel you want to hear.
I hope my comment has served you
Greetings Franco Dosil
Hola Melissa, si los canales predefinidos, no puedes encontrarlos, porque se han borrado, puedes resintonizarlos y memorizarlos, a continuaci?n tenes la forma para hacerlo
Elegir una estaci?n de radio
1. Elija la funci?n de sintonizador. El sistema pasar? por defecto a la ?ltima estaci?n en la que se ajust? el sintonizador antes de que se
remoto.
2. Use el bot?n BAND para elegir AM, FM 1 o 2.
3. Use el bot?n TUNING UP (+) o DOWN (-) para seleccionar la estaci?n de radio que desea escuchar.
• Presionando el bot?n +/- una vez mover? el sintonizador de manera incremental.
• Si presiona y mantiene presionado el bot?n +/-, el sintonizador buscar? autom?ticamente la siguiente frecuencia
transmitiendo claramente. "AUTO" aparecer? en la pantalla.
4. Presione el bot?n FM MODE para cambiar entre FM Est?reo y FM Mono para una mejor recepci?n de las estaciones de FM. Ser
Sin embargo, tenga en cuenta que solo puede recibir emisoras de FM en est?reo si se emiten en est?reo.
Programaci?n de presets
Su sistema es capaz de almacenar hasta 24 estaciones de radio preestablecidas en la memoria (8 de FM1, 8 de FM 2 y 8 de AM)
durante el tiempo que la unidad est? enchufada, y hasta dos semanas despu?s de que se haya desconectado la alimentaci?n de CA.
1. Elija la estaci?n de radio y la banda que desea almacenar.
2. Presione el bot?n MEMORY para activar el modo Preset.
3. Seleccione un n?mero de presinton?a usando los botones PRESET UP () o DOWN () para seleccionar el canal de preset que desea escuchar.
4. Presione MEMORY nuevamente para bloquear su elecci?n.
Una vez que haya terminado de programar sus selecciones en la memoria del sistema, solo necesita usar PRESET UP o
Los botones ABAJO en la unidad para buscar la frecuencia deseada. En el control remoto, use el teclado num?rico para seleccionar el
N?mero del canal preajustado que desea escuchar.
Espero te haya servido mi comentario
Saludos Franco Dosil
RCA Audio... | Answered on May 06, 2019
Hello Fredrick, for what you describe, it would seem that the transformer of your Teac has been shorted, the power is 190 watts, according to the user manual
I searched the Internet for the service manual and I was not lucky
You could look for someone to rewind the transformer or copy it and make a new one, I do not know the possibilities that you can do this in your area
Also try to connect with the nearest RCA representation and ask for assistance
Finally, look for a specialized technical service
I hope you find a solution to your concern
Hola Fredrick, por lo que describes, parecer?a se ha puesto en cortocircuito el transformador de tu Teac, la potencia es de 190 watts, seg?n el manual de usuario
He buscado en Internet el manual de servicio y no he tenido suerte
Podr?as buscar quien te rebobine el transformador o te lo copie y haga uno nuevo, no conozco las posibilidades de que puedas realizar esto en tu zona
Tambi?n prueba conectarte con la representaci?n de RCA mas pr?xima y pedir asistencia
Por ultimo busca un servicio t?cnico especializado
Espero que encuentres una soluci?n a tu inquietud
RCA Audio... | Answered on Apr 30, 2019
There are lots of methods. You can resort to online music download website, chrome extension, or music download software. Follow below steps, to know the detailed information. Leawo Music Recorder is a super recording software to help you record various kinds of music from multiple sources like online music like YouTube, computer audio, and built-in input audio. The recorded music files will be saved into an output format of MP3 or WAV.
1. Run Music Recorder on your computer and enter the recording interface. Audio source should set firstly before music recording. In order to record the music from YouTube, we should choose the option "Record Computer Audio".
2. Click the red button "Start" to make Leawo Music Recorder begin to work. Then play the music on YouTube. You should note that the music recorder should work prior to playing YouTube music.
If you want to decide the start and duration time of the recorded music, just click the icon button "Task Scheduler" then you can finish this customized setting as per your requirement.
After the music has been recorded from YouTube, you can use Leawo iTransfer to move the recorded music from computer to your iPod
Leawo iTransfer is a professional transfer program for transferring files between iOS devices, iTunes and computer. Various kinds of files are supported by this software such as music, apps and photos, etc.
1. Run Leawo iTranfer after you have downloaded the music on your computer. Connect your iPod with your computer via USB cable. The library of your iPod will be detected automatically and shown in the left sidebar of the window.
2. Import files to the software from computer in the following four-way:
I. Drag and drop the music files into iTransfer directly.
II. Click the button "Add" on the upper part which is beside the left sidebar.
III. Click the button File > Add > Add File/Add Folder on the top right corner of the window.
IV. Right click on the library and select Add File or Add Folder.
3. A pop-up dialog will be shown once you finish adding files and press the "Transfer" button. The name and the quantity of the transferred files will be demonstrated to let you know the transferring percentage. Remember not to disconnect your Apple device to your computer until the transferring is completed.
music-recorder-recording-t-ptaos1411zhprwnu0jdtasew-5-0_0.jpg For more details, check: How to Download Music from YouTube to iPod
RCA Audio... | Answered on Apr 19, 2019
You may need to buy a new player l reckon.
RCA Audio... | Answered on Apr 03, 2019
What do you mean by the leads are "flat type" on the Marantz? Are you referring to the speaker wire output terminals? If so, the graphic equalizer should be connected to the pre-amp input of the amplifier, not the speaker level outputs.
RCA Audio... | Answered on Mar 31, 2019
3 questions posted
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
ddigital voice recorder rp5022b
  • Audio Players & Recorders
