20 Most Recent Mitsubishi VS-55707 TV Questions & Answers
If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Disassemble procedure to many popular brand TVs are given in detail, with illustrations. Do a search by brand name.
Mitsubishi... | Answered on Jan 02, 2014
No. That model does not even support 3D. The technology did not exist when that model was made.
Mitsubishi... | Answered on Apr 19, 2011
Hello
From your brief description, it seems to be the fault with its front panel power ON/OFF switch itsef. It is a common fault to most of the TVs that the contact inside the switch gets worn out during long run, as at these junction inside the switch, spark will occur during each ON/OFF. Se can't see this spark, as this contact is inside the switch. This is a double pole double throw type, and can be get from most of the electronics components spare parts shops. you yoursef can do it at home, as this is not a skilled work. Open your TV, locate the ON/OFF switch, cut the wires connected to it keeping some convenient length so that you can identify the connections by the wires' colour, when you refit it. The switches are of many types in both diamensions and quality, choose the right one. Keep the switch of your tv in hand as sample. Take an exact replacement with same diamensions. Wish you Good Luck. OK.
Your power supply board is not yet dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Mitsubishi... | Answered on Apr 18, 2011
Overheating circuit board may be, the logic board may need some capacitor or transistor replacements
Mitsubishi... | Answered on Mar 01, 2011
this kind of problem can be caused by failed capacitors on the DM power board. Check the below link, you will find the service or repair manual for your TV. This will guide you on how to get to the DM board.
http://www.free-service-manuals.com/Television/Mitsubishi/Mitsubishi_VS-55707_Service_Manual_L56156/
(Note that you need to register on the with the above link before the service manual can be downloaded. Registering is free so as downloading).
Also, to order for a repair kit to fix DM board problems, visit; http://www.tvrepairworld.com/mitsubishi_repair_kits
Good luck.
Mitsubishi... | Answered on Feb 15, 2011
Yes, You can buy another screen for Your mitsubishi television, You can get it from any part dealer store, also, You can get it from someone whose television is having a different problem than a faulty screen. There are some television that develop other kinds of fault, therefore, they are moved to stores where they can be disassembled and sold in parts.
Hope this information helped. Thank You for using FixYa!!!
Mitsubishi... | Answered on Jan 15, 2011
That would be the CRT Board to Red Tube,Mats Electronics did have some CRT boards $9.95
1-800-628-1118
Encompass Parts Distribution might have them 1-800-638-3328
Mitsubishi... | Answered on Jan 14, 2011
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Mitsubishi... | Answered on Dec 09, 2010
Have a service guy over. Sounds like a power supply gone bad.
They can be repaired.. but get a quote
Mitsubishi... | Answered on Aug 09, 2010
i had the same problem. im sorry to say that you are out of luck and you tv is on the way out. i had the same problem and spend $100's of dollars to have people come and try and fix it to no luck. sorry
Mitsubishi... | Answered on May 23, 2010
There is a power supply fault condition inside. Contact service center.
Mitsubishi... | Answered on Apr 20, 2010
NEED TO TURN THE TIMER OFF
Mitsubishi... | Answered on Feb 15, 2010
look to see if you see the word PIP on remote or tv if it does, then you do
Mitsubishi... | Answered on Feb 14, 2010
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Mitsubishi... | Answered on Jan 02, 2010
Yes, connect cable to Ant A and ensure the TV is on the input for Ant A.
Then go into the setup menu and ensure that the Input is set to Cable not Antenna.
Next, choose the auto program option to load your channels.
If you still don't get a picture and you have a small tv to bring to this outlet try this and make sure you are able to get a picture.
If you still can not get a picture then the outlet is not active and you need to call your service provider and ask them to activate the outlet for you.
THE TUBE IS REPLACEABLE, HOWEVER YOU MUST VERIFY IT IS BAD FIRST. THERE ARE 3 OTHER PROBLEMS THAT YOU NEED TO ELIMINATE FIRST BEFORE YOU SPEND $250.00 ON A NEW TUBE.
Mitsubishi... | Answered on Dec 28, 2009
THERE ARE 2 CURRENT LIMITERS 1 OHM OR SOLIDER IN FUSES FOR + & - SUPPLY THEY FEED THE CONVERGENCE IC'S YOU NEED TO VERIFY YOU HAVE YOUR POWER SOURCE TO THESE. ALSO A LOSS OF VERTICAL DEFLECTION WILL CAUSE THIS.
It seems that your power supply unit (PSU) has gone. The click when you plug in shows that the current is reaching the PSU but does not go ahead of it. Is there any other sign of life beside the click sound initially. Any lights coming on or some other sound you may hear? Please clarify.
Mitsubishi... | Answered on Dec 18, 2009
Mitsubishi VS-55707 TV Logo
67 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
mitsubishi vs 55707 couple
  • Televison & Video
