20 Most Recent Mitsubishi VS-4544 45" TV Questions & Answers
Its a old set but hookup should from a DVD player be to the rear audio and video inputs---note color of jacks on player--you will need for that old set composite--yellow(video and color), red and white for sound.
If the player does not have them (composite) you have a real problem.
Once connected use the input button on the front of the set to change to that input that you hooked the player up to (video 1 or 2 etc.)
Mitsubishi... | Answered on May 29, 2012
solder alot of connections on power supply board and in deflection/ High voltage section on deflection board.
Mitsubishi... | Answered on Jan 18, 2011
No,require new main video backlight board,and vertical/horizontal stablelizer board also.Both boards alone cost u about $500 bucks not uncluding labors yet.
Mitsubishi... | Answered on Oct 20, 2009
You got a issue with the power supply if the green light goes off and does not bring it back to standby.
One of th issues could be a bad capcitor, A fuse, a resistor its hard to tell without me doing a visual inspection on the unit. I would have a estimate done on it if it cost more then $150 upwards it would be in your best intrest to replace the tv at that point. But I would have the power supply checked.
If you like my advice please rate the solution.
Thanks
Rulds2008
Fixya Expert moderator.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Mitsubishi... | Answered on Oct 12, 2009
check the power supply section.. probably the electronic component got problem.
Mitsubishi... | Answered on Jun 04, 2009
I'll take a guess here that the lines are at a slight angle. I believe that these are "retrace" lines and are an indication that the flyback transformer is starting to fail. The vertical IC would cause a collapse of the picture and bad caps in the circuit would effect the linearity of the picture. You can check for poor solder joints as they could cause any nunber of symptoms.
Keep us posted.
Dan
Mitsubishi... | Answered on Apr 22, 2009
 high voltage regulation problem. need tech service.
Mitsubishi... | Answered on Dec 01, 2008
lose connection is a common problem of tv, try to resolder but be careful of short circuit ,
Mitsubishi... | Answered on Oct 21, 2008
Sounds like the Horizontal Output Transistor shorted. TVs are dangerous to work on if you are not trained. The transistor can be checked easily with a dmm. If it is bad the flyback should probably be replaced too. If it is ok, you have a short somewhere else and need to isolate systems until the fuses quit blowing or hook it up to a variac and do checking to see where the short is. My bet is on the HOT. Again, if you are not qualified have a professional look at it. Good luck.
Mitsubishi... | Answered on Jun 23, 2006
No error code 61 listed, only a 66 error code which indicates lamp issues:
66
A) Lamp did not turn on at P-ON sequence... Check CJ4 circuitry
B) No Lamp Inserted............... No Lamp inserted
C) Disconnected cable between ballast and lamp.... HV connection or lead wire to lamp.
D) Lamp-Enable goes to PWB-MAIN but not to Ballast....Lamp Cartridge Failure
for lamp see the following web site: http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73638
recommend using the manufacture part# as many replacements for Mitsubishi will not work.
Mitsubishi... | Answered on May 09, 2019
Shorted circuit board.
Mitsubishi... | Answered on Apr 10, 2019
Could be you need to set the output volume on your receiver for the soundbar. Most receivers allow volume output for each speaker
Mitsubishi... | Answered on Apr 02, 2019
Televison & Video Logo
18 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
need horiz button help mitsubishi 45
  • Televison & Video
