20 Most Recent
Mitsubishi CS-32307 32" TV Questions & Answers
Game console hook up
What type of hookups are on the back of tv ? Do you have an HDMI hookup if so try using that If your tv comes with a game mode look in back before u hook it up to place it in right spot. One last thing why don't you try hooking up old fashion way buy adapter for regular cable hookup and use channel 3 or4 that might help
MY TELEVISION DOES'NT POWER UP.
HelloCheck its horizontal output transistor for short circuit. It is a common fault to all type of CRT based TVs, and show this type of fault. If it is found shorted [collector to emitter], the LOT should also be checkd for winding short [internal]. Normally; LOT cannot be checked with normal measuring instruments. If LOT has internal winding short, the horizontal output transistor will get overheated and finally shorted. Replace the horizontal output transistor first, and check whether it heats up ubnormally within seconds after switch ON the Tv. If it heats up so, make sure that the LOT is defective, and it should also be replaced. OK.
TV power button comes on to turn tv on &
Hello
This could be alot of things but I tend to lean towards a power supply issue. The short story is that when your tv starts up, it checks alot of things to make sure they are correct. If one of the voltages is off, then the tv protects itself and turns back off. In my experience when they turn back off its almost always power supply issues. It could be a card pulling down the powersupply, or the neat gizmo that powers the light. But I have not seen alot of that.
Generally if its not a power supply fault that the tv just cant tolerate it will flash a code at ya. Blink blink (Im messed up and here is the number of the fault) Blink blink BLINK!
I wish I had better news, however powersupplys are one of the cheaper and easier things to fix.
Best of luck
11/25/2010 12:08:10 AM •
Mitsubishi...
Answered
on Nov 25, 2010
Hellow
i have a
Unfortunately, if you don't have the option of accessing the menu using the panel buttons and/or the speaker control isn't in the menu, you will have to purchase a replacement remote from the manufacture.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Mitsubishi VCR HS-U580 guide rollers not moving forward all the way. Cassette would not load. Also noticed drum not spinning when powered on
Your Mitsubishi VCR HS-U580 looks to have a problem with the information rollers and drum. Here are some things to check:
Look for something blocking the VCR or cassette compartment that would possibly be stopping the guide rollers.
Check the belt that drives the VCR mechanism. If it is loose or broken, you may also need to substitute it.
Clean the video heads using a head-cleaning cassette to make certain they're not dirty.
See if the drum motor is working. If it is not spinning, there may be an issue with the motor.
If the trouble persists, it's an exact idea to get assistance from a professional technician or contact Mitsubishi's purchaser support for advice.
Be cautious when dealing with electronic devices, and if you are not certain what to do, it's great to get assistance from an expert.
Where could I download a copy of a service manual for mitsubishi hs-u580 vcr?
i think finding a downloadable service manual for your Mitsubishi HS-U580 VCR might take some searching, but here are a few options:
Check the official Mitsubishi website's support section. They might offer downloadable manuals for older models.Many online appliance parts stores like RepairClinic or AppliancePartsPros stock service manuals for various brands and models. Search for your specific VCR model to see if they have it available.Websites like ManualsLib or iFixit sometimes host user-uploaded service manuals. While the availability and quality can vary, it's worth checking. If online options fail, consider purchasing a physical copy of the service manual from online marketplaces like eBay or Amazon.
Remember, some websites might charge a fee for downloading manuals. Always be cautious of suspicious websites and download from reputable sources.
I own a Mitsubishi 1080 1EEE 1394 television. Yesterday, we had a planned power outage in our area. When the power was restored, the only picture I can get is flipping horizontal lines?
Hoping you did not have electric overload that damaged the power supply, try unplugging the set and push the button On until no lights indicate anything. Then wait about an hour so the capacitors would empty themselves further. Next plug it back in and see if this worked. It is never wrong to push the edges a little in finding if the cables that go around the screen have a problem at that point. When one opens the TV (off power and unplugged) these flat cables should be checked for corrosion and right position in connectors. Corrosion is caused by little moist only, combined with the electricity. Then see if capacitors from the power supply, or any at all, have expanded tops. Those are the larger and smaller towers with metal on top that is divided in three parts. New ones alike can then be ordered but replacing requires basic skills. Further examples can be found on YouTube. Capacitors are common to fail early. Those larger ones have dangerous high voltage and can hold their charge for long span of time. it is not uncommon for devices like this to fail after being off.
