Mitsubishi WS-73615 73" TV
Problems with Mitsubishi WS-73615 73" TV?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Troubleshooting and Support
Solved Problems for Mitsubishi WS-73615 73" TV RSS Feed
Click here to get instant support from our best Experts!
View More Results for Mitsubishi WS-73615 73" TV
Questions and Unsolved Support Problems
Unsolved Problems for Mitsubishi WS-73615 73" TV RSS Feed
Answer
i have a 73 inch mitsubishi and it is verry dark brightness is all the way up yet it is still berly... (More)
Answer
no color on screen 73 in dlp tv also will shut off after warning shows on screen picture its like... (More)
Answer
my tv powers up for a second then shuts down it says blocked air flow but theres lots of room behind... (More)
Find a Manual
Mitsubishi WS-73615 73" TV Manuals & Guides
WikiManual
(Post a New Chapter)
How to Repair a Remote Control
Don't put up with your faulty buttons on you Remote Control anymore! If some of the keys on your remote have stopped working or you have to push... by wikihow
Upload Manuals
Tips & How To Guides for the Mitsubishi WS-73615 73" TV
Earn cash by writing Tips & How-To's.
It's easy!  (Learn more)
My Magnavox TV is showing a feature screen
Press the channel up and volume down buttons at the same time on the front of the tv until the set goes off. When you turn the set back on the feature... written by rusty_etech
Magnetized TV, Poor picture, blotches, discolored, target shaped image
If your set looks like the one pictured above it is likely magnetized and needs to be degaussed (or demagnetizing). All CRT type TV's are prone to... written by johnnydiode
Help FixYa, Help you and help others. Share your User maunals and...
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for... written by stoneheaded
DTV transition: Options for Those with Analog TVs
On Feb 18, US viewers with analog TVs will no longer receive free over-the-air programming. In other words, if you've got an older TV with rabbit ear... written by Lauren_FixYa
Removing parental lock on RCA and GE TV sets
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method... written by techman
repair job update
Update A number of people have commented that after changing the color wheel, their red and blue colors are reversed. This is a different color... written by sweet_rascal
repair job continued
7. Locate the color wheel cover. It?s got a small green circuit board on top of it with a black/blue wires connected to it. Remove that plug. Also,... written by sweet_rascal
Purchase a Color Wheel & The Repair Job
My television is model Samsung HLM4365WX and the color wheel part number for that is BP96-00250A. This color wheel is used in many, many Samsung... written by sweet_rascal
I need help with
near zipcode:
Please enter your zipcode
Search
Top Repair Providers for Mitsubishi WS-73615 73" TV
Nationwide | 859-609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
Ratings for the
Find a Warranty
Specifications for Mitsubishi WS-73615 73" TV
Key Features
Screen Type
Flat Screen
Diagonal Screen Size
73 inch
Digital TV Standard
HDTV
Display Capabilities
Aspect Ratio
16:9
Built-in Tuner
NTSC · ATSC
Broadcast Format Supported
1080i (HDTV) · 480p (EDTV) · 480i (SDTV)
Remote Control
Remote Control
Standard
Illuminated Remote
Illuminated
Image Quality
Velocity Scan Modulation
With VSM
Comb Filter
3DYC / 3D Digital
Audio Features
Audio Output
Fixed
Audio Type
Stereo
Technical Features
Picture in Picture
With PIP
Connectors
Rear Input Connectors
Component x 2 · S-Video x 2 · Audio (RCA) x 5 · Composite x 2 · RF x 2 · HDMI x 1 · FireWire x 2
Front Input Connectors
Composite x 1 · Audio (RCA) x 1 · Firewire (IEEE 1394) x 1
Rear Output Connectors
Composite x 1 · Audio (RCA) x 2
Speakers
Number of Speakers
2 Speakers
Speaker Power
2 x 10 Watt
Dimensions
Depth
29.93 in.
Height
66.12 in.
Width
65.43 in.
Weight
395 lb.
Warranty
Overall Warranty
1 Year
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Describe your problem:
Top Standard... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
