20 Most Recent Hannspree HF207HPB Monitor Questions & Answers
It may have damaged the power supply(PS) and a fuss is possible, but you may not recognize the fuss on the circuit board. Open up the monitor and take a look. Also take the Number down off PS and look-up on line. A used/refurbished PS. eBay a good place to look
Hannspree... | Answered on Dec 03, 2017
You could use some tissues with alcohol and unionized water, so it prevents electrical shocks (these are probably around 2 bucks tops at any electronics shop.)
1. Turn your monitor off and unplug it.
2. Wipe in a single direction the whole screen (preferably horizontally.
3. Let it dry for 10-15 mins.
4. Enjoy your now super clear monitor :)
Hannspree... | Answered on Jun 08, 2013
One of two general ways--if of course rear screws go that way, a lot of the monitors the entire front has to be pried off and is held with plastic snaps--you have to go in from front of set to get at the board/s.
If removal of rear cover is not possible (it may also have the snaps) I usually will use a thin metal putty knife to get the snaps loose going around either the front frame of the screen or the rear, has to be either from front or rear.
Take you time and do not use too much force or you will cause damage.
Hannspree... | Answered on Dec 17, 2012
You need to reload the driver you got with your monitor. Native resolution for the HF207HPB is 1600 x 900. Once you've loaded the proper driver you should select this screen resolution.
Still having problems? Contact zvuv@neandertech.com
Hannspree... | Answered on Aug 11, 2011
Click on the link below :
http://www.hannspree.com/US/images/Downloads/HF-Series/Driver/HF207_Vista.zip
Download the installation package to a temporary folder on your PC.
Run the downloaded file, and follow the instructions that appear.
Hannspree... | Answered on Jun 02, 2011
I'm guessing you are trying to change to fullscreen mode, press F11 while in internet explorer and it will enter fullscreen mode. Press F11 again to return to normal.
Hannspree... | Answered on Mar 02, 2011
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Hannspree... | Answered on Dec 18, 2010
Not sure why you would need an internet connection to recover data. Maybe it has ransomware on it? There are CD's you can burn that can run a Linux environment and check fr malware. The Hirens CD comes to mind.. Try downloading it, burn to CD or create a USB install and run some malware programs on it. Or use a Windows 10 install to reinstall a new system.
Hannspree... | Answered on Jun 12, 2018
Hannspree HF207HPB Monitor Logo
15 questions posted
Top Hannspree Computers & Internet Experts
 Mike M
Mike M
Steve Allison
Steve Allison
DBurstiner
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Hannspree Computers & Internet
Most Popular Question
hf289h electrical transformer in
  • Computers & Internet
