20 Most Recent
Visioneer NetScan 4000 Questions & Answers
I am unable to manipulate a document after
Most of the scanners require that you set up the scan first and the software that comes with them will NOT do much if any editing. Be sure and export the document/photo in a FORMAT that is editable. Then use other software such as photoshop or MSWord to edit the document after. The software provided with scanners is usually pretty lame when it comes to editing.
11/18/2010 3:35:15 PM •
Visioneer...
Answered
on Nov 18, 2010
Visioneer RoadWarrior 4D- Calibraton Sheet, Copper Paper. I need to buy one or two of this
I cannot provide specific recommendations for where to purchase items. However, you may be able to find a calibration sheet for the Visioneer RoadWarrior 4D scanner online or through a retailer that specializes in office equipment or computer accessories. You may also want to try contacting Visioneer directly to inquire about purchasing a calibration sheet for your scanner.
Keep in mind that you may need to provide the model number and serial number of your scanner when making a request for a calibration sheet, so it may be helpful to have this information available. It is also a good idea to confirm that the calibration sheet you are purchasing is specifically designed for the Visioneer RoadWarrior 4D scanner and is made of copper paper, as this may affect its compatibility and performance.
Universal drivers
Go to Visioneer product support site support.visioneer.com/ , enter your model number and search for installation drivers
My roadwarrior 120 scanner wont install drivers i have windows 7 64
Uninstall the drivers which are already in your computer and install a fresh version of it. Try going to the website of the manufacturer to find the driver and install it in your computer.After doing that, update the drivers in your computer so that you can make sure that they'll work great. You can use RadarSync which you can get from here http://bit.ly/rsdriverI hope this helps!David
How can i stop my
Hi dsimmons421
assuming your are under Windows 7 :
go to " Start /Devices and Printers " . Right click on the printer icon , select " see what's printing " click on " documents / cancel .
best regards ,
fanaudi .
