20 Most Recent Kingston Combo 4GB DTI USB and 4GB (KWB164G3CQ) Media Questions & Answers
https://www.partition-tool.com/resource/manage-partition/format-a-write-protected-usb-flash-drive.html
Kingston Combo... | Answered on Dec 03, 2017
Open lock to enable.
Kingston Combo... | Answered on Nov 13, 2017
Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box I have found better results ticking the first box then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
you might need the software installed on your computer needed to read the files
IE: adobe ,direct x , codec ,
Kingston Combo... | Answered on Jan 15, 2013
W 7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. for XP or earlier click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts if you need more help with this or if i have missed the problem post a reply Hope it helps.
click start click to open on my computer you should see your Usb drive E: right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure all 3 boxes are ticked full control change and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your Usb Drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Kingston Combo... | Answered on Mar 09, 2012
Your documentation may have the password.
If not then try the word "password" without the quotes.
Kingston Combo... | Answered on May 25, 2011
I use them all the time, you can do copy and paste or cut and paste.Just right click with your mouse on what you want to copy/cut click on either one take it over then go to your media right click again and select paste and it then will be on your media ready to use.
I hope this helps you out if it does please leave me some feedback.
Kingston Combo... | Answered on Apr 03, 2011
If you are talking about the SD card, there's a tiny switch on the sideopposite the angled corner.
It must be slid towards the electrical contacts edge of the adapter. The other position is write protected.
Kingston Combo... | Answered on Feb 27, 2011
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Kingston Combo... | Answered on Jan 15, 2011
Look for a small switch on the side that "locks" the card. flip the switch and try it again.
Kingston Combo... | Answered on Jan 04, 2011
A virus may have got to it :/ its hapened to me before. What you can do is reformat it. Right click on My Computer and see if the device is noticed in Disk Management under Storage. If so you can right click on it and hit format :) hope this helps. If you cant see it try it on another computer :)
Kingston Combo... | Answered on Jan 03, 2011
Sorry to read about your problem, I hope this helps you out.
You may want to try it in a friends machine, but ii sounds like you pen drive is defective...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Kingston Combo... | Answered on Dec 22, 2010
You need free software to remove the passowrd for your USB. try this http://www.fileguru.com/apps/usb_disk_password_remove_sata/p3
Kingston Combo... | Answered on Nov 24, 2010
The best thing to do is to try it in a friends computer, remember to scan it with an anti-virus program if it is detected. Otherwise it is possible that the USB flash drive has malfunctioned or needs to be reformatted. Hand it over to a PC technician maybe he/she can recover the information on it. Might be time to purchase a new one as they do wear out.
damnor01
Kingston Combo... | Answered on Nov 15, 2010
Try to see if there is a small tab on your USB's side that can be adjusted either up and down; that is the write protect tab.
Please let me know if you find this assistance helpful. Thank you for using FIxYa.
Kingston Combo... | Answered on Oct 11, 2010
Format the drive as there can be errors or virus in the memory.
Once done check if the new files can be stored.
Kingston Combo... | Answered on Sep 21, 2010
install proper software for the usb mass storage
Kingston Combo... | Answered on Sep 10, 2010
Kingston Combo 4GB DTI USB and 4GB (KWB164G3CQ) Media Logo
27 questions posted
Top Kingston Electronics - Others Experts
jairo sanchez
Håkan Sterner
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you a Kingston Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Kingston Electronics - Others
Most Popular Question
remove write protect from usb
  • Electronics - Others
