20 Most Recent
Mach Speed Eclipse 180SL 4GB MP4 ECLIPSE180SL4GB Motherboard Questions & Answers
How do i transfer music from amazon,com to my
hi,
from amazon purchased on a pc? It would download the file to your machine. usually in the downloads folder it creates in you My Documents/ folder. from there it is a cord that would attach the device to the PC and the OS should pic it right up as a new device. you can usually browse them with my computer. and copy and paste music to the music folder on the device
GL
Hope this helps
Don't forget to vote for me
Thanks
Jammer
My 180SL 4GB Eclipse is frozen on the opening
Same happened to me. I called the support number in the manual 580-272-0035, and they gave me the reason and the fix. The reason is improperly disconnecting the device from a USB port. This can cause the firmware to be corrupted. The solution is to allow the battery to completely drain, then before connecting to any power source, press the play button for 30 seconds. This resets the firmware. How to properly disconnect from a USB port is on page 17 of the manual and applies to any device.
My Eclipse 180 Mp3 media
remove battery and try again, if this does not fix the problem, you might have to reset the device, by pressing the power button for a long time while turning the device on instead of once. then following the instructions reset the device.
you may have to download and install new drivers for the device from the internet after the reset.
you will possibly lose your data stored on the device.
My Eclipse 180RD 4GB Mp3
it is most likely the internal battery. You can try moving the data by connecting it to a computer.
10/14/2014 10:56:44 PM •
Mach Speed...
Answered
on Oct 14, 2014
