20 Most Recent Cisco Linksys E1000 WirelessN Broadband Router Network Routers Questions & Answers
Leave the user name blank and enter the password admin ( admin once only ).
Try this.
If that doesn't work then search for the Cisco connect software on your main computer. You might have installed the cisco connect software on your main computer while installing your router.
If it is windows computer then cisco connect software might be under All Programs.
If is a MAC computer then cisco connect might be under Applications.
Open cisco connect software.
Click on router settings. You will see the router name and password. If you click on Advanced settings, it will open the setup page.
If nothing is working then you will need to reset the router and reconfigure it.
Remember once you reset the router, you will need to reconfigure it from the scratch.
Click to see more information about cisco connect software
Cisco Linksys... | Answered on Nov 23, 2018
if your laptop detect more wireless signals my be your router have issues if not may you need to try installing a new wireless card $10 on ebay
Cisco Linksys... | Answered on Oct 11, 2018
Go to www.hp.com select support, enter the model number HP Pavilion xxxxx and run diagnostics.
Cisco Linksys... | Answered on Feb 09, 2018
Here is the answer from Linksys itself-
The default IP Address is 192.168.1.1. Leave the username field blank and the password is "admin".
Key to this is to leave the username field BLANK.
Cisco Linksys... | Answered on Nov 20, 2017
What errors are you getting when you try to play?
Cisco Linksys... | Answered on Jun 09, 2017
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Cisco Linksys... | Answered on Jan 03, 2017
Most likely this is not a problem with the router, but with the modem or the connection that at&t is providing to you.
I would suggest calling at&t and have them check your connection.
You should check the filters on each of your phones jacks to make sure that they are in place and properly connected. Additionally, you should check the wiring for any damage or poor connections in your phone lines.
Cisco Linksys... | Answered on Dec 28, 2016
Linksys Tech Support 1 800 585 2494 Contact for free diagnose by support on Linksys technician.
Cisco Linksys... | Answered on Sep 27, 2016
Cisco Linksys E1000 Wireless-N Router Router Default
Cisco Linksys E1000 Wireless-N Router Default IP:
192.168.1.1
Cisco Linksys E1000 Wireless-N Router Default Password:
admin
Cisco Linksys E1000 Wireless-N Router Default Username:
linksys
Cisco Linksys... | Answered on Jul 21, 2015
If you are just starting, please follow the instructions in the user guide. It will step you through the process, and you should be up and running in no time. Here is a link to the user guide if needed: http://www.winotek.com/multimedia/items/E1000_V10_UG_USA_NC-WEB,0.PDF
Cisco Linksys... | Answered on Feb 03, 2015
all depends on the make but genraly if you login to your router usually its admin then password admin again or changeme or what ever password you have been given then go to wifi settings and its usually at the botum of that page have fun
Cisco Linksys... | Answered on Nov 08, 2014
getting ip starting 169.x.x.x ... cannot access router config page. Even reset don't work
Cisco Linksys... | Answered on Nov 02, 2014
If you forgot Windows password, you can create a Windows password reset bootable CD/DVD or USB flash drive to reset your lost or forgotten Windows password, i have created a bootable CD with the tool Windows Password Breaker and reset my administrator password successfully.
Cisco Linksys... | Answered on Aug 15, 2014
Try Username: admin and password : admin or username: admin and password: password
Cisco Linksys... | Answered on Aug 07, 2014
Make sure DHCP is enabled, and the wifi password is correct (if you use any).
Cisco Linksys... | Answered on Jul 28, 2014
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Cisco Linksys... | Answered on Jun 16, 2014
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
226 questions posted
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
J John
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Cisco Computers & Internet
Most Popular Question
signs wireless router failure death
  • Computers & Internet
