20 Most Recent
Arrowhead Brass PK1390BCLD Vacuum Breaker 3/4 Hose Thread Self-Draining - Each Questions & Answers
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
2 days ago
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
Scotts lawn mower 21995x8b manual
I'm guessing you have fixed this or given up after 13.5 years, but here is my suggestion for the next person who has this trouble. If you ran it out of fuel and left it over the winter, it could have a drop of fuel that hardened and plugged one of the fuel ports in the carburetor. I have had this happen and needed to remove the fuel bowl and poke the dried film with a pin. Put it back together and it started right up.
3/31/2024 1:19:11 AM •
Garden
Answered
on Mar 31, 2024
Where can i find choke cable for 422707 model # riding mower.
Do not know what brand that is, but you can find choke cables at lowes, amazon .com. or any number of small engine repair shops depending on where you live. An after market cable could be easier to find and work just as well.
3/30/2024 4:44:30 AM •
Garden
Answered
on Mar 30, 2024
What are the advantages of using HDPE pond liner sheets for constructing a pond?
Here are the advantages of using HDPE pond liner sheets for constructing a pond:
- Durability and Puncture Resistance: HDPE is a tough material that can withstand wear and tear. It's resistant to punctures from rocks, roots, or other sharp objects that might be present in the soil under your pond. This translates to a long lifespan for your pond liner, minimizing the need for replacements.
- UV Resistance: Unlike some materials that degrade under sunlight, HDPE liners are UV resistant. This means they won't become brittle or break down over time when exposed to the sun, ensuring the liner lasts for many years.
- Chemical Compatibility: HDPE is non-toxic and resistant to many chemicals. This makes it safe for fish and plants in your pond, and it won't leach harmful chemicals into the water if you need to treat the pond with certain substances.
- Suitable for Large Ponds: HDPE liners come in large sheet sizes, making them ideal for constructing bigger ponds. The large sheet size reduces the need for seams, which can be weak points in a liner, and simplifies the installation process for larger ponds.
- Relatively Easy Installation: While professional installation is always recommended, HDPE liners are lighter than some other pond liner options and can be workable for DIY projects. They can be welded together to create a secure seam, and their flexibility allows them to conform to the contours of your pond.
- Cost-Effective in the Long Run: Although the upfront cost of HDPE liners might be higher than some other options, their durability and low maintenance requirements make them a cost-effective choice in the long run. You won't need to replace them as often, and they can help prevent leaks that could damage your landscaping or require repairs.
3/18/2024 7:08:38 PM •
Garden
Answered
on Mar 18, 2024
