20 Most Recent Orion TVDVD091 9 in. TV/DVD Combo Questions & Answers
If sound when a vcr is connected the set is ok as far as sound goes--something is not connected or right with the settings in the menu or if you have a headphone jack built into the set it may be the issue.
Combos are like this--one part does not work and it becomes useless.
The headphone jack if it has one is your best hope--supposed to cut audio off when a jack is inserted but the jacks on the rear or front bypass that.
Orion TVDVD091 9... | Answered on May 01, 2012
Hello
Setup codes for Orion TV with GE universal remote control are:
0121 / 0135 & 0035
OK.
Orion TVDVD091 9... | Answered on Aug 20, 2011
You should be able to do a channel search and come across the inputs either at the upper end or the lower end of the channel search. Using the channels on the TV itself, not cable or satellite, scroll through the channels until the desired input is found. Once on the desired input open the DVD player and insert a DVD and close the drawer. The DVD should start to play automatically. When it gets to the place on the DVD to actually "play movie" press the select/enter button on the remote. As for the replacement remote I would get a universal remote. They are far fairer in price than an original replacement remote and every bit as reliable. Just make sure to take the model of your TV/DVD player with you to make sure the remote you purchase is compatible. You probably need to go no further than your local hardware store or department store. Save on the shipping too. However if you are set on getting the original remote here is a place http://www.orion.newremotecontrol.com/catalog_item.php?catnum=076R0DT090 they also sell a few generic remotes for a few dollars less.
Regards, Tony
Orion TVDVD091 9... | Answered on Apr 17, 2011
Most RCA and GE universal remotes can be programmed to work with your equipment. Walmart has one for less than $8 that works with most units, and also works with DTV tuners. You may have to program the DVD and the TV as two separate buttons
Orion TVDVD091 9... | Answered on Jul 26, 2009
8 amp fast blow type.
Orion TVDVD091 9... | Answered on Apr 09, 2009
Use the TV/CAP/TEXT button on the remote to turn off the text box function of the closed caption decoder.
Orion TVDVD091 9... | Answered on Feb 25, 2009
Call the customer service number on the back of the set.
Orion TVDVD091 9... | Answered on Oct 24, 2008
Use code search on the URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Orion Televison... | Answered on Apr 07, 2019
This is not really a question. Please rephrase it and be specific. Please keep in mind that some of us answering your question has never come in contact with your product- we answer off intelligence however it is far more difficult to answer your questions when we have to figure out accompanying information on our own. Normally sets that allow multi screen (putting together multiple sets to make one big tv) use some type of splitter (cdmi) and then each tv needs to be set to the position it will be in etc. the remote recover is a another story and mostly depends on preference. Do a little research and find out whats needed to get what you need, and we will help you along, but please be specific about what you need and want and the steps you have taken. good luck
https://www.6ya.com/mrmmike
Orion Televison... | Answered on Mar 02, 2019
Yes they all came with remotes unless it is an ancient top loader.
Orion Televison... | Answered on Feb 13, 2019
Google (orion)(24 2468w)(manual) without parens.
Orion Televison... | Answered on Nov 21, 2018
Orion TVDVD091 9 in. TV/DVD Combo Logo
17 questions posted
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Orion Televison & Video
Most Popular Question
no sound
  • Televison & Video
