20 Most Recent
Orion PM4202 Television Questions & Answers
All my dtv channels are on the wrong number
Hello, the older tuner in this set limits the channels you get and they are all over the place. if you have the owners manual they will have the conversion chart, but there's nothing you can do to correct the problem.....thanks, Terry
What is the code for sky remote to operate orion
please follow the steps below:
TV
RED + SELECT
TV
0236
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Can I hook a genie Wi-Fi camera up to this TV, ORION MODEL NO:TVDVD092
It's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. In general, most modern TVs have built-in Wi-Fi connectivity and support for applications like Netflix and Hulu, which allow you to stream video from the internet directly to your TV. However, not all TVs support all types of Wi-Fi cameras, and some cameras may require additional hardware or software in order to be used with a TV.
In order to connect a Wi-Fi security camera to your TV, you will need to check the specifications and compatibility of both the camera and the TV. If your TV has built-in Wi-Fi and support for streaming applications, it may be possible to connect the camera directly to the TV using the Wi-Fi network. Alternatively, you may be able to connect the camera to a computer or mobile device and then use an HDMI cable to connect the computer or mobile device to the TV.
In summary, it's possible to connect a Wi-Fi security camera to a TV, but whether or not it will work with your specific TV model will depend on the capabilities of the TV and the camera. It's best to check the specifications and compatibility of both the camera and the TV in order to determine the best way to connect them.
Can a wifi geeni camera be set up to my ORION MODEL NO:: TVDVD092
It is not possible to directly connect a Wi-Fi Geeni camera to an Orion TV model number TVDVD092. The Orion TV model you have mentioned is a television set that is not capable of connecting to a Wi-Fi network or functioning as a Wi-Fi network device. In order to use a Wi-Fi Geeni camera, you would need a device that is capable of connecting to a Wi-Fi network, such as a smartphone, tablet, or computer. You can then use the Geeni app on that device to set up and control the camera.
