20 Most Recent Sony EX33LPS Headphones Questions & Answers
you can make both of the earbuds work. You can open the earbud where the speaker is that you use to hear the musik. Use a soldering iron and a lead. check if the wire inside has removed, fix it back and you will hear sound on both earbuds.
Take care.
Sony EX33LPS... | Answered on Dec 21, 2016
Hello Susan, for what you are saying, you would have a problem with the mechanism of the player, very possibly some stretched strap, which does not have enough tension to make the displacement
I suggest you look for a specialized technical service
Greetings Franco Dosil
Hola Susan, por lo que comentas, tendrias un problema con el mecanismo del reproductor, muy posiblemente alguna correa estirada, que no tiene la suficiente tension para hacer el desplazamiento
Te sugiero busques un servicio tecnico especilizado
Saludos Franco Dosil
https://www.hifiengine.com/hfe_downloads/index.php?sony/sony_hcd-a195_d250_g2000_service_incomplete_en.pdf
https://www.hifiengine.com/hfe_downloads/index.php?sony/sony_lbt-d250_g2000_en.pdf
Sony Audio... | Answered on Jun 20, 2019
Sarkari Result is providing the results of government Exams and admit card of the government exams. We provide the updates of the government exam results and admit cards. We provide the Updates of the government exams. We provide the admit card of the government exams and you can also know your result from this website.
Sony Audio... | Answered on Jun 17, 2019
Hello Joanne, the Sony CDP-C225, is a 5 CD audio player
To listen to your Sony CDP-C225, on your Toshiba 46sl412u, you have to connect the LR audio output of the Sony to the LR ColorStream® HD / VIDEO audio input on the back panel of the Toshiba, then turn on the equipment, charge the CD on the Sony and you put in the Toshiba the Video input and there you can listen to the music of your Sony
I send you the links to download the manuals of Sony and Toshiba
I hope you can interconnect the equipment and enjoy the music
Hola Joanne, el Sony CDP-C225, es un reproductor de 5 CD de audio
Para escuchar tu Sony CDP-C225, en tu Toshiba 46sl412u, tienes que conectar la salida de audio L R del Sony a la entrada de audio L R ColorStream® HD/VIDEO en el panel posterior del Toshiba, luego prendes los equipos, cargas los CD en el Sony y pones en el Toshiba la entrada de V?deo y ah? puedes escuchar la m?sica de tu Sony
Te env?o los links para que descargues los manuales del Sony y del Toshiba
Espero que puedas interconectar los equipos y disfrutar de la m?sica
https://support.toshiba.com/support/modelHome?freeText=2941924
https://data2.manualslib.com/pdf2/25/2419/241856-sony/cdpc225.pdf?aca4bda68ee4e97a5d512bb41ffa4c33&take=binary
Use code search on your unidentified URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Sony Audio... | Answered on Jun 10, 2019
on this error read out - battery could be the problem is its battery operated - try hard wire to the wall outlet if u have a adaptor or maybe new batteries- of course the heads in the machine could be out of alignment- try another CD- do the easy steps first- if the walkman is real old, maybe its time for a new one if all other issues fail to solve problem -- also u could open machine up to see if a wire is burnt or has become loose. solder joints sometimes let go or a wire breaks
Sony Audio... | Answered on Jun 09, 2019
Sony EX33LPS Headphones Logo
1 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
did left earbud become silent
  • Audio Players & Recorders
