20 Most Recent
Recoton Advent Advent Q1435A TV Questions & Answers
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).It will have either individual output transistors or a single IC.What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Broken screen
trash it.. cost of a broken screen is typically close to the cost of a new set.
Codes
I need the code for Advent Q1435 to use on my Direct TV remote.
I have a Dell 19
Try these :
1.) reinstall your operating sys .
2.) sounds like there is a short somwhere. is it under warranty?
3.) Check the plug-in for the external power pack. Mine did the same thing and it turned out to be an old and week connection at the plug... the contacts were not fully making.
Let me know if teh above are OK .. !
