FixYa.com
Sampo SME-32DL5 32" TV
All Products > Sampo > Standard Televisions
Problems with Sampo SME-32DL5 32" TV?
Search inside Sampo SME-32DL5 32" TV Knowledgebase
Troubleshooting and Support
Solved Problems for Sampo SME-32DL5 32" TV RSS Feed Post a New Problem
How to Fix "Rabbit Ears" on an...
How to Fix "Rabbit Ears" on an old TV?
1 Solution
Sometimes the screen image on my TV will...
Sometimes the screen image on my TV will roll, but my set has no vertical roll adjustment. How can I fix this?
1 Solution
The picture on my TV screen is dim. I know...
The picture on my TV screen is dim. I know the picture tube is fine. What else could it be?
1 Solution
What's the difference between LCD...
What's the difference between LCD Flat-Panel and Plasma Flat-Panel?
1 Solution
Menu appears by itself. Sometimes stays...
Menu screen comes on and sometimes stays on. Sometimes it goes off and then comes back on. The light touch buttons...
1 Solution
Tv won't stay on
My tv comes on, the power light comes on, but it won't stay on, it goes off by itself a few seconds later. Is there a...
1 Solution
Sanyo ds27930
I need to know how much it would cost, or if it is even worth the trouble of replacing the board within my tv. The cable...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Sampo SME-32DL5 32" TV RSS Feed Post a New Problem
Sampo Monitior
SME-32DL5 I want to know how to connect to my direct TV? Thanks
Post a Solution
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen TypeFlat Screen
Diagonal Screen Size32 inch
Display Capabilities
Aspect Ratio4:3
Image Quality
Invar Shadow MaskWith Invar Shadow Mask
Connectors
Headphone JackWithout Headphone Jack
Dimensions
Depth22.9 in.
Height28.3 in.
Width34.1 in.
Weight156.5 lb.
Warranty
Overall Warranty2 Years
Sampo Contact Information
Main support number1-888-373-4368
Email supportinfo@regent-usa.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
