20 Most Recent
Hobby Zone Firebird Commander 2 RTF Electric Questions & Answers
Have hobbyzone firebird commander 2,
Some RTF aircraft are not quite RTF as they sometimes need trim adjustments. Also, a wing could be heavier on one side than the other as RTF models are mass produced with cheap and cheaply assembled components.
For a quick balance check, remove the prop and obtain an electrical terminal block (aka Chocolate block). You will need just the brass terminal insert with both screws.
Remove the prop and put the terminal onto the prop spindle. On the other open end of this, you need to insert a small curtain hook (ones that are used to hold up net curtain wires). Insert this into the other end. To the hook, tie a short length of nylon or cotton. Suspend the cotton from a platform such as a shelf. You need to be able to hang the aircraft without it touching the wall but it needs to be close to the wall. Once done, obtain a tape rule and measure the leading edge END of the wing. Move the tape to the other wing and make sure that the same position aligns with the same mark on the rule. If it doesn't, you need to add a minute amount of weight. About a gram, to the higher wing.
If it is fine, then remove the cotton and then tie a loop into it. Make another cotton string loop identical and hang it one plane length away. Using a small piece of sticky tape, tape the cotton to the tape and then to the extreme top of the tail fin. Loop the other cotton loop over the prop spindle, making in effect a cradle system. Again, use a tape rule to ensure that the both wings sit at exactly the same height. Add a piece of tape to the lighter wing to level it. A better way is to use nail varnish as it levels itself and prevents wing surface issues.
If both wings are okay, then it may be the tail fin rudder. It could be stuck on the right side rather than in the middle. This makes the aircraft fly to the right the faster the speed is, even taking off. Try trimming the rudder with the trim control on the transmitter or servo link.
If all else fails....buy a model boat as it could be the operator....
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning.
Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off.
Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction.
Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages.
Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues.
Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below.
https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM •
Toys
Answered
on Feb 22, 2024
Can I fix an error on my orthofix 2212 it shows
Why are you guys giving answers to fix a printer when the OP is asking how to clear the error code on an orthofix bone growth stimulator used to help the bones fuse together after back surgery... I'll give my best guess as I am having the same issue. They are set to last a certain amount of time and designed to stop working after that set time. In my case I got the device, postponed my surgery and my orthofix wouldn't work after I actually had the surgery.. 2nd best guess would be a battery issue because I can charge mine fully, turn it on for about 10 min, put ot back on the charger and it flashes all 4 bars like its completely dead.. but there is a number you can call that can help you more than I can, 18005354492
1/17/2024 9:11:13 PM •
Toys
Answered
on Jan 17, 2024
How ca i overcome my
Tried and tested solutions.
Go out and take deep breath and in your mind say 'I want to get rid of this bad habit"
1/4/2024 6:43:12 PM •
Toys
Answered
on Jan 04, 2024
How to reset my nsfas password because u don't remember it anymore
If you want to reset your nsfas password, here is what you should do.
- Go to www.nsfas.org.za
- Click nsfas account
- Click 'forgot password'
- Type in your ID number
- Choose one of the following options:
- I can't remember my username
- I can't remember my password
- I can't remember my username and password
- Choose the relevant option
- Click 'submit'
- A One Time Pin (OTP) will be sent to you via SMS and email to the cellphone number and email you provided
- Check your cellphone or email for the OTP. This OTP is only valid for 24 hours
- Type the OTP number in the provided block
- Click 'submit'
- A link to reset your login details will be sent to you via email and SMS
- Click on the link that was received through SMS or email
- Follow the reset process
- Create a new password by following the instruction on the screen
- Click 'submit'
And you're done. You should now have a new password set on your nsfas account.
12/25/2023 1:31:19 PM •
Toys
Answered
on Dec 25, 2023
