20 Most Recent One Industries CLOSEOUT One Industries Womens Rockstar Picassa T-shirt-Motocross Gear Questions & Answers
google first, then into picassa, try from there. are you on a cell-phone trying too do this? if so; its another bag of buggs.
One Industries... | Answered on Apr 18, 2017
great mercadolibre com mx http://www.soccerphysicsonline.com/
Motorsports | Answered on Jan 15, 2018
you need to post what engine you need firing order for
Motorsports | Answered on Nov 30, 2017
Check for a bad fuse..not sure where it is but look in the owners manual or inside cover of the fuse panels for the wiring diagram
Motorsports | Answered on Sep 14, 2017
The alarm you hear may be the overheating alarm... but, if it is, it won't run too long with it on before the engine locks up...Is there evidence of water coming from the witness hole in the back of the motor? Good.. otherwise,, you may be hearing the low oil alarm..or the oil pressure alarm...My bass boat oil system alarm goes off every time I crank the engine..but it uses oil and runs great...(been doing it for years - I am too lazy to clean the sensor in the oil tank)
The RPM and faster alarm is something that puzzles me?
Motorsports | Answered on Jun 14, 2017
in manal that you have recived in the car should be explained what every fuse is doing.
Motorsports | Answered on May 31, 2017
Go to a smaller exhaust or a longer exhaust (not practical. Engines need some back pressure. That is why headers on dragsters are all of equal length.
Motorsports | Answered on May 30, 2017
Believe it or not, Home Depot, whom I despise. A low/bad chip should not cause slow engine crank, if that is what you meant. Show crank is low amperage. Weak starting battery or electrical connections at either the battery or the engine.
ARE YOU SURE IT IS A FUEL DELIVERY PROBLEM? SPARK & FUEL ARE THE 2 THINGS THAT CAUSE A VEHICLE TO START AND RUN. IF IT USES "COILPACK(S) HAVE THEM /IT TESTED...LIKE AT AUTO ZONE...OTHER IGNITION SYSTEMS, MAKE SURE YOU ARE GETTING A FAT STRONG SPARK OUT OF COIL!....WHEN YOU TURN THE IGNITION SWITCH TO RUN POSITION (DON'T CRANK IT OVER)....WITH THE DRIVERS DOOR OPEN..YOU SHOULD HEAR A WHIRRING SOUND MOMENTARILY FROM THE REAR OF THE VEHICLE. THIS IS THE FUEL PUMP RUNNING. IF YOU DONT HEAR A FAINT HUMMING...THE FUEL PUMP
1. IS DEFECTIVE
2. IS NOT GETTING POWER
3. YOU HAVE A RELAY OR WIRING ISSUE (UNDER HOOD MAXI FUSE AS WELL). IF NOISE IS HEARD..GO TO SPARK DIAGNOSIS JEFF GEYER (517) 489-1566 OWNER AUTOWORX
Motorsports | Answered on May 18, 2017
unencrypt the question! lol?
Motorsports | Answered on Mar 26, 2017
First of all let me tell you that it is a myth that you can not go back and forth between conventional oil and synthetic or in your case synthetic blend. They all mix very well together but why on earth would you not use a full synthetic in every thing? It will keep your motor so much cleaner, and last way longer, new or 150.000 miles used, does not matter. They refine the synthetic oils way way longer to get the impurities out. Other big thing [ OILTEMPERATURE AND WEAR COLD START UPS ] Exceeds and blows conventional out of the water. plus a real full synthetic you can run a lot longer just spin a new good grade filter on or change it. Me my self Ill run Walmart full synthetic in my grand prix and ROYAL PURPLE in my 2013 mustang. I think there all full synthetics are good compared to the old dirty sludge and if all the new manufactures are recommending it now its good. Do you have any motor rebuilders or trucking builders close to you? Just go look at the oil pans to compare the too . I guarantee you will be sold that day and never run conventional again.... PERIOD.
Motorsports | Answered on Feb 09, 2017
Call around, the one that is busy is the one you want.
Motorsports | Answered on Feb 02, 2017
call around the ford veteran and modified car clubs to see what information you can get
they are the most likely people that can help you
Motorsports | Answered on Dec 21, 2016
coudl be the speed sensor. or trans computer
Motorsports | Answered on Nov 01, 2016
A flashing SES light is a misfire and can cause severe engine damage. You need to have the computer scanned and post the codes here for more help. It could just simply need a tune-up.
Check fuel pump pressure, fuel filter for clogged, fuel line if purged, fuel tank valve which is attached to the chassis above the fuel tank.
Motorsports | Answered on Aug 22, 2016
Most new generation cars has this feature to warn you that something is wrong. To explain further when your auxiliary fan
is not working on the engine is hot, this causes the high pressure side on your ac system to reach around 350 psi and thru a sensor cuts off the ac compressor. This causes the ac not to work until the pressure goes back to normal.
Motorsports | Answered on Jun 13, 2016
With a growler and a hacksaw blade cut to the correct length
Motorsports | Answered on Mar 06, 2016
remove fuel pump relay run engine till it stops (no fuel pressure in line remove clamps with hose clamp pliers wqe7ruull fule lines from filter then undo the clip at the other end of the two short pieces of fuel line and discard insert the two new pieces of fuel line in the kit put the 4 hose clamps on the new fuel hoses 2 on each insert the filter into the flexible hoses and refit the two hose clamps replace the fuel pump relay turn on ignition and wait for fuel pump to stop
start engine + check for fuel leaks at filter or hoses
One Industries CLOSEOUT One Industries Womens Rockstar Picassa T-shirt-Motocross Gear Logo
1 questions posted
Top One Industries CLOSEOUT Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
rapboy 55
rapboy 55
Level 1 Expert
Are you an One Industries CLOSEOUT Motorsport Expert? Answer questions, earn points and help others
View Most Popular
  • One Industries CLOSEOUT Motorsports
Most Popular Question
google plus sign in
  • Motorsports
