hi i have yamaha dvr s150. every time i try to play a disk won't read it. it says no disk. help me...
(More)
HI I HAVE YAMAHA DVR S150. EVERY TIME I TRY TO PLAY A DISK WON'T READ IT. IT SAYS NO DISK. HELP ME PLEASE
I wanted to know If I can actually set these speakers along with another reciever.. I can't find in...
(More)
I wanted to know If I can actually set these speakers along with another reciever.. I can't find in the manual if the speakers are 4 or 6 oms Thanks
My DVD-player (DVR-S150) works in all modes very good, except when I put a DVD in. It says Reading...
(More)
My DVD-player (DVR-S150) works in all modes very good, except when I put a DVD in. It says Reading DVD and after a couple of seconds it switch off. I reconnect all the speaker and system cables, switched of the power and turned it on again, but without any success. Can you please advice in this regard?
When you get no disk error, that is usually because of a problem with the
optical laser lens that is dirty, faulty or opaque, and will...
written by ginko
To reset the recorder to factory defaults as if it was just removed from the box - leave the recorder on then press and hold the channel up and down...
written by xmarine2847
You can help other;s and maybe they will help you. This can be done by uploading a copy of you user manual and any service information for the...
written by stoneheaded
My LG DVD recorder was unreliable when recording TV broadcasts to "standard" DVD disks. Frequently it would begin recording a show and then...
written by MateusDIY
You should always read the owners manual to familiarize, yourself with the operations of the unit. This will solve a lot of simple operation problems...
1)just open the player 2)remove the rubber belt connecting the dc motor 3)you
can open the disc tray now 4)if there are any dust particles or...
written by dileep007
It is always suggested that you use or buy a cd or dvd cleaner with it's cleaning solution, but I have discovered something that works just as well if...
written by BobbyR1234
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
