20 Most Recent Dewalt Hammer Drill Sds2x18 V Batt 5 Sds Bits Cordless Questions & Answers
0answers
When ever I put on my battery on my dewalt charger the indicator light blinks faster than normal while charging
Possible reasons for this behavior: Blinks Long (Red Light): If your battery is too hot, the charger will blink the red light rapidly and for an extended duration. To prevent this, ensure that your battery is not exposed to direct sunlight or excessive heat. Give it some rest to cool down. Blinks Short: If the battery is too cold, it will blink short and fast. This could be due to prolonged exposure to cold temperatures or the battery being idle for an extended period. Allow the battery to charge for a while or bring it to room temperature to resolve this issue. Blinks Very Fast (Doesn't Go Away): If the light is blinking very fast and persists, it indicates that your battery has gone bad and needs replacement.
4/16/2024 5:36:07 AM • Dewalt Drills • Answered on Apr 16, 2024
I have a DeWalt D2570 - GB. Stopped working. On disassembly I found a bare wire from the capacitor. Where should it go?
A photo would greatly help with your issue, are both wires still attached to the capacitor?? in not, the capacitor must be replaced with one of the same value, if the capacitor is ok, look for a wire with solder on the end but nothing else attached to it, or a solder point on a card with a hole in it or a solder joint that has broken free from the card,,, if you can solder well, and have the equipment,. it is good at this point because You'll need to re-solder them back together,, again a photo will help me greatly in telling you exactly how to fix
2/15/2024 1:40:25 PM • Dewalt Drills • Answered on Feb 15, 2024
Common problems for Dewalt DCR025 JobSite Radio?
Read the reviews. We see them on Fixya very occasionally and from memory, it was internal fuses blowing. https://www.google.com/search?q=Dewalt+DCR025 ..
11/27/2023 7:25:28 PM • Dewalt Drills • Answered on Nov 27, 2023
How do I get a stuck bit out of my DeWalt dc 895?
https://www.youtube.com/watch?v=pNDgV_6k12E Reverse and Forward Mode: Try putting the drill in reverse mode and hit the trigger, then forward mode. If that doesn't work, tap the tip on the driveway but don't slam it. It should release . Use a Wrench: First, make sure that the chuck is in the locked position. Next, use an allen wrench to loosen the set screw on the side of the chuck. Finally, unscrew the drill bit from the chuck . Remove Chuck Collar: Use a wrench or pliers to loosen the chuck collar and remove it from the chuck. Then, use a screwdriver or other tool to remove the chuck jaws and any other components that may be blocking access to the stuck drill bit. Once these components are removed, you should be able to access the drill bit and remove it from the chuck .
10/29/2023 7:06:06 AM • Dewalt Drills • Answered on Oct 29, 2023
Missing component off of Dewalt DCB107 board. Need component ZD1 name
It's going to be a zener diode, that's the easy part, you will need to know the voltage as well, only way to know that is find a good charger and measure the voltage drop across the diode with a multimeter or find a schematic.
8/20/2023 6:20:01 PM • Dewalt Drills • Answered on Aug 20, 2023
Wire placement on switch of DeWalt DWD520 hammer drill
Here are the wire placements for the switch of a DeWalt DWD520 hammer drill:
  1. The red wire from the motor goes to the top left terminal on the switch.
  2. The black wire from the motor goes to the top right terminal on the switch.
  3. The white wire from the power cord goes to the bottom left terminal on the switch.
  4. The black wire from the power cord goes to the bottom right terminal on the switch.
It's always recommended to double-check the manual or contact DeWalt customer service for confirmation, as wire placement may vary depending on the specific model and year of manufacture.
5/1/2023 6:41:49 PM • Dewalt Drills • Answered on May 01, 2023
I have Dewalt D26501 and it will not run. I have a red light flashing at the rear of the drill, i'm getting full power but, as soon as you press the trigger, the red light flashers but, no go.
The red light flashing at the rear of your DeWalt D26501 could indicate a few different issues with the tool. Here are some potential causes and troubleshooting steps you can try:
  1. Battery issue: If you're getting full power but the tool won't run, it's possible that the battery is not delivering the correct voltage or is not making proper contact with the tool. Try removing the battery and reseating it firmly in the tool, making sure it clicks into place. If the battery is still not delivering power properly, try charging it fully or using a different battery to see if that resolves the issue.
  2. Trigger issue: If the red light flashes but the tool does not run when you press the trigger, it's possible that there is an issue with the trigger itself or with the wiring connecting it to the motor. Try checking the trigger for any visible damage or debris, and make sure it moves freely when pressed. You may also need to check the wiring connections inside the tool to ensure they are secure and not damaged.
  3. Motor issue: If neither the battery nor the trigger seem to be the issue, it's possible that there is a problem with the motor itself. This could be caused by a number of factors, including a burned-out motor or a malfunctioning component inside the tool. If this is the case, you may need to take the tool to a professional technician or contact DeWalt customer service for assistance.
Overall, troubleshooting issues with power tools can be challenging, and it's important to take appropriate safety precautions when working with them. If you're unsure about how to proceed or are not comfortable working on the tool yourself, it's best to seek professional assistance.
2/26/2023 10:08:36 AM • Dewalt Drills • Answered on Feb 26, 2023
I have brand new Dewalt drill and it will work then stop?
Charge the battery and try again. If still bad, make a warranty claim. You can't beat their warranty, they have great faith in the product!
Warranty Information' DEWALT
https://www.dewalt.com > support > warranty DEWALT Mechanics Tools are covered by the manufacturer's FULL LIFETIME WARRANTY. If any DEWALT Mechanics Tool ever fails for any reason, DEWALT will replace it.
1/1/2023 4:13:56 AM • Dewalt Drills • Answered on Jan 01, 2023
Is there a reset on a dewalt dw008 cordless recip
no there is not.
11/29/2022 1:17:51 AM • Dewalt Drills • Answered on Nov 29, 2022
2answers
Dewalt D21570 red light flashing what is the problem
Check battery. put a new in and works?
11/28/2022 2:37:04 PM • Dewalt Drills • Answered on Nov 28, 2022
Hi, need a replacement clutch for a Dewalt Dc222
notify dewalt --online search --a tool repair shop in your area
8/11/2022 9:47:23 PM • Dewalt Drills • Answered on Aug 11, 2022
2answers
Hi My dewalt sds hammer drill won't work in hammer mode, but works on the other. I've had it a couple of years. I was wondering if anyone could give me some help as I'd like to fix it myself? But I'm
A small part that helps the switching is probably broken. Go to the dewalt site and the service online in order to find the faulty part. It would be cheap if you want to buy it. Your can repair it by yourself.
8/9/2022 2:26:13 AM • Dewalt Drills • Answered on Aug 09, 2022
Change chuck on dewalt 236 1/2 13 mm vsr drill Dont know how to get it off pls help
There is a torx headed screw inside the chuck that is reverse thread (Right hand to loosen) - remove that then the chuck will spin off standard thread (Left hand loosen) Most of the time I chuck a 1/2" allen wrench into the chuck, mount the drill in a vise, and strike the wrench with a hammer to get the chuck off
6/14/2022 4:32:32 PM • Dewalt Drills • Answered on Jun 14, 2022
The light on Dewalt drill stopped working. Is that fixable?
yes it can be fixed, there is no fuse.
3/28/2022 11:11:13 PM • Dewalt Drills • Answered on Mar 28, 2022
How To Remove Chuck Screw From DeWALT DWD520 Hammer Drill
Open the jaws and insert a Torx 20 driver. The thread is counter clockwise.
12/12/2021 1:47:57 PM • Dewalt Drills • Answered on Dec 12, 2021
Dewalt Hammer Drill Sds2x18 V Batt 5 Sds Bits Cordless Logo
2 questions posted
Top Dewalt Drills Experts
Sean Wright
Sean Wright
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
View Most Popular
Dewalt Drills
  • Dewalt Drills
Most Popular Question
could tell any outher battery charge
  • Drills
