20 Most Recent
Heavy Duty Arrow Ht30 Light Wire Hammer Tacker Questions & Answers
A staple jammed in the moving part (driver?) when
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
How do I adjust the depth the brads are counter sunk
There is a dial located by the business end of the Brad that adjusts the depth it fires. Also make sure you air pressure ( written on the stapler ) is set to level issued by the manufacturer. It'll say something like max pressure 90 psi. That would mean you will need to adjust the regulator pressure on your compressor to no more then 90 psi or to what ever number that is written on that sticker. Use a test piece of wood and turn the pressure down if you have no luck until you get the desired results.
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
