20 Most Recent
Clarke Power Products Clarke 180en Mig Welder Complete Wire Feeder Parts Questions & Answers
Mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
I see spots after welding.
Tig is very brite.If your seeing spots I would try another hood for awhile.If the battery is to weak or you can't adjust up to shade 12 for tig it can be very hard on your eyes.I would try a regular hood on some scrap and see how that works.I couldn't change the battery in my hood so I just had to buy another one.One other thing check for leaks in your hood.You've already done that more than likely.
Do you need a cheater lens?
We6523 WANT WELD
Check thermal overload. Also make sure the ground clamp connection is sound.
