20 Most Recent Yamaha GX-700 Shelf System Questions & Answers
There is a small hole just above the door on most CD changers. Unwind a small paper clip and GENTLY push it into the hole. This should release the door, and let you look inside. Don't force it because you could damage it more than it is already.
Yamaha GX-700... | Answered on Jun 15, 2012
Remove the short that is causing the protection to engage, then power cycle, assuming it's a short circuit protection. If it's going in to thermal protection, then shut the receiver off and let it cool. If all speaker wires are disconnected and the unit is cool to the touch but still appears to be in protection mode, likely one of the output transistors has failed an will need to be diagnosed and replaced. Don't neglect to check the ESR of the electrolytic capacitors if you find a failed device internally.
Yamaha Audio... | Answered Yesterday
Hello Michael, for what you comment, you have connected the X-Box to the Yamaha through a Digital-A converter
First try another sound source, example FM, if you also chop the right channel, the problem is in the audio output of the Yamaha
If FM is heard properly, then try replacing the RCA RCA cable between the Digital-A converter, if it still continues, change the input on the Yamaha and if it still follows the fault, replace the D-A converter
I hope you can solve your concern
Greetings Franco Dosil
Hola Michael, por lo que comentas, tu tienes conectado el X-Box al Yamaha a trav?s de un conversor D-A
Primero prueba otra fuente de sonido, ejemplo FM, si tambi?n se entrecorta el canal derecho, el problema esta en la salida de audio del Yamaha
Si se escucha bien FM, entonces prueba reemplazar el cable RCA RCA entre el conversor D-A, si aun continua, cambia la entrada en el Yamaha y si aun sigue la falla, reemplaza el conversor D-A
Espero puedas resolver tu inquietud
Saludos Franco Dosil
https://www.hifiengine.com/manual_library/yamaha/rx-v690.shtml
https://de.yamaha.com/files/download/other_assets/4/334534/RX-V690.pdf
Hello Alice, the problem of your Yamaha is mechanical, so you comment, it is very possible that you have the traction strap of the CD tray stretched
Find a specialized technical service and maintain the mechanism
I hope you can solve the problem
Hola Alice, el problema de tu Yamaha es mec?nico, por lo que comentas, muy posible que tenga la correa de tracci?n de la bandeja porta CD estirada
Busca un servicio t?cnico especializado y que le hagan un mantenimiento en el mecanismo
Espero puedas resolver el problema
Yamaha Audio... | Answered 2 days ago
Most audio units have a small rechargeable battery to maintain memory inputted items like favourite channels.
This is your Service Manual. Page 117 mentions the battery cover and AAA battery.
https://www.manualslib.com/manual/1090806/Yamaha-Rx-V463.html
Yamaha Audio... | Answered on Jul 12, 2019
Hello Dez, indicate the models of your Yamaha that you are commenting, in order to find the best possible solution
I wait your answer
Hola Dez, indica los modelos de tus Yamaha que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Yamaha Audio... | Answered on Jul 05, 2019
None of them, you will to buy a quality phono preamp to go in between. page 17
https://usa.yamaha.com/files/download/other_assets/6/319936/RX-V363_U.pdf
Yamaha Audio... | Answered on Jun 29, 2019
Hi Tyrone, I'm looking at the Yamaha HTR 3063 manual and it does not have the Tape-Monitor function, which would allow you to have the connections for an equalizer
This happens because of the variety of types of audio signals and they can not be processed for the insertion of an equalizer
Eventually, you could equalize a single signal, which you would connect to the EQ input and the EQ output, connect it to any of the RCA L-R audio inputs
Hola Tyrone, estoy viendo el manual del Yamaha HTR 3063 y no cuenta con la funci?n Tape-Monitor, la que te permitir?a tener las conexiones para un ecualizador
Esto sucede por la variedad de tipos de se?ales de audio y no se pueden procesar para la inserci?n de un ecualizador
Eventualmente, podr?as ecualizar una sola se?al, que la conectar?as en la entrada del EQ y la salida del EQ, la conectar?as alguna de las entradas de audio RCA L-R
https://usa.yamaha.com/files/download/other_assets/7/321147/HTR-3063_om_en1-1.pdf
https://data2.manualslib.com/pdf3/65/6430/642969-yamaha/htr3063.pdf?6a90cbe355c2bdc4e399d09c40d1a7ab&take=binary
Yamaha Audio... | Answered on Jun 25, 2019
It's in protection mode. Disconnect all speakers and hold the Tone and Straight buttons while hitting the power button. Hold all buttons down for 3 to 5 seconds. This will turn off protection mode. Now power down then back on. If you haven't damaged anything it should work fine. Make sure all speaker connections are good. Always power down the unit before making any speaker or other connections.
Yamaha Audio... | Answered on Jun 22, 2019
Hello Kevan, for what you say, I do not think your Yamaha is in Sleep mode
Try using another outlet to power the equipment, and see if the fault continues
Try disconnecting the speakers and see if the fault continues, if you continue, you would surely have a power supply problem
If it does not go on, see the baffles connected one by one until it fails again
Check that the connecting cables of the speakers, do not have loose copper wires, that can generate a short circuit in the output
I suggest you look for a specialized technical service
I hope you can solve the fault
Hola Kevan, por lo que comentas, no creo que tu Yamaha, se encuentre en modo Sleep
Prueba utilizar otro toma corriente para alimentar el equipo, y f?jate si continua la falla
Prueba desconectar los parlantes y f?jate si sigue la falla, si continua, seguramente tendr?as un problema de fuente de alimentaci?n
Si no sigue, ve re-conectando de a uno los bafles hasta que te haga nuevamente la falla
Revisa que los cables de conexion de los parlantes, no tengan hilos de cobre sueltos, que puedan generar un cortocircuito en la salida
Te sugiero busques un servicio tecnico especializado
Espero puedas resolver la falla
https://de.yamaha.com/files/download/other_assets/8/327568/RX-V463_G_en.pdf https://www.manualslib.com/manual/1090806/Yamaha-Rx-V463.html
Yamaha Audio... | Answered on Jun 18, 2019
Hello Gerardo, check the impedance of your speakers are 8 Ohms or more, if they are less than 8 Ohms, you can produce the failure you say
It also checks the real power that each speaker can handle and that is according to the manufacturer's specifications
Check the connections of the speaker cables, which do not have copper hairs that are joining between the positive and the negative
Test, disconnect all the speakers and go connecting one to one and try in high volume, then disconnect that and connect another and tests, so with all
This test is to know if you have any speaker with problems
If you can not solve, look for a specialized technical service
Hola Gerardo, comprueba la Impedancia de tus bafles sean de 8 Ohms o mas, si son de menos de 8 Ohms, puede producirte la falla que comentas
Tambien revisa la potencia real que puede manejar cada parlante y que este de acuerdo a las especificaciones del fabricante
Revisa las conexiones de los cables de parlantes, que no tengan pelos de cobre que se esten uniendo entre el positivo y el negativo
Prueba, desconectar todos los parlantes e ir conectando de a uno y probar en volumen alto, luego desconectas ese y conectas otro y pruebas, asi con todos
Esta prueba es para saber si tienes algun parlante con problemas
Si no logras resolver, busca un servicio tecnico especializado
https://usa.yamaha.com/files/download/other_assets/1/334221/RX-V995.pdf
https://www.manualslib.com/manual/197447/Yamaha-Rx-V995.html
Yamaha Audio... | Answered on Jun 13, 2019
The internal microcomputer has frozen, due to an external electric
shock (such as lightning or excessive static electricity) or to a drop
in the power supply voltage.
Hold down z (power) on the front panel for more than 10 seconds to initialize
and reboot the unit. (If the problem persists, disconnect the power cable from the AC wall outlet and plug it again.)
Yamaha Audio... | Answered on Jun 11, 2019
Do the lights come on? The click is the relay throwing the unit into prtection mode. Check to make sure the speaker wires are secure in back and not touching each other...
Yamaha Audio... | Answered on Jun 10, 2019
Yamaha GX-700 Shelf System Logo
4 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
cd changer won 39 t open mechanical
  • Audio Players & Recorders
