20 Most Recent Yamaha HTR-5850 Receiver Questions & Answers
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
Yamaha HTR-5850... | Answered on May 09, 2017
EVER HEARD OF SOMETHING CALLED GOOGLE???
GOOGLE SEARCH! USE IT!!!
yamaha htr 5850
Google
The very first thing on the GOOGLE list is that model on the Yamaha website where you can download the manual.
The second thing on the GOOGLE list is the very manual itself.
Yamaha HTR-5850... | Answered on Oct 19, 2016
most likely something wrong in the amplifier section. Have you tried powering it on with no speaker wires attached? If it stay on with no speaker wires, then there is a bad wire or speaker.
Yamaha HTR-5850... | Answered on Mar 26, 2014
It could be that the amp's overload protection circuit is being triggered by a feedback loop or other problem, such as a shorted or bad cable connection. Turn off the power and unplug the receiver. Look for problems, starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. Plug it back in and power up again. Immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine) before the delayed speaker amp output clicks on. Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component.
Make sure you don't have a feedback loop due to a recording device feeding back a signal. All VCRs and CD/DVD-recorders should be hooked up to the VCR, DVR or TAPE/CD-R "IN/OUT" jacks with IN being connected to the cables marked OUT on the deck and vice versa. (That confuses even us experienced guys sometimes!)
Also, no MONITOR video or audio outputs should be connected to the recording decks, nor should the TV outputs be fed back to the recorders. The same goes for the digital IN/OUT jacks for CD recorders; use only the same number IN as OUT for each component (For example, Optical IN/OUT #4 and #5 are the two digital IN/OUT pairs on the Denon AVR-380X series.)
Yamaha HTR-5850... | Answered on Jan 23, 2013
If it doesn't have a jack made for plugging Mp3 players into it like the new car stereo's do than you just have to go buy an FM transmitter that is made for Mp3 players. It will play through one of your low FM frequency's on your receiver. You can generally pick one up for around $20
Yamaha HTR-5850... | Answered on Dec 12, 2011
Look at the manuals for both, please. It's in there.
Yamaha HTR-5850... | Answered on May 28, 2011
Try running digital audio from the source - cable/sat - to the receiver. The fewer intervening connections and entities, the better. TV's are NOT considered sound sources for high end purposes or we wouldn't have Yamaha HTR-5860's and better speakers, would we?
Yamaha HTR-5850... | Answered on Apr 23, 2011
Some features do not give surround sound such as tuner. If input cables attached to analog dtv/cbl and speaker cables attached to wire end output serround should work fine when set to dtvcbl on front display.
Get a 1/8" miniplug-to-RCA-cable adapter and plug the headphone output directly into any compatible input on the receiver. Press PLAY.
Read the article (it's short). Don't buy into the hype about better cables. IPOD's don't stack up as hi-fi to begin with and cables are cables are cables....
http://www.dummies.com/how-to/content/connecting-your-ipod-to-a-home-stereo.html
Yamaha HTR-5850... | Answered on May 29, 2010
How is TV sound coming into your Yamaha? If it's from the TV analog audio then maybe the TV's audio output is muted.
If it's from the Cable Box maybe ITs audio is muted. I'd refer to the guide for the Cable Box.
MUTE on the receiver is not source-specific.
Yamaha HTR-5850... | Answered on May 25, 2010
Does the speaker setup fail the same way?
Yes? Internal amplifier problem.
If No - What source(s) do this?
If just one - reverse its Left and Right inputs to determine which cable or channel on the input device is faulty.
Yamaha HTR-5850... | Answered on May 23, 2010
Yamaha HTR-5850 Receiver Logo
43 questions posted
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
hook ipod yamaha device
  • Audio Players & Recorders
