20 Most Recent
B&W 5.5" TV/CD+G Monitor Karaoke Machine Television Questions & Answers
Blank karaoke machine
Try looking on the back of the machine for vertical and or horizontal hold controls (marked V-Hold and H-Hold) and try adjusting them, especially the horizontal hold.
If that doesn't help, then the next troubleshooting step would be if the machine has a video output you could try connecting to a TV/Monitor and see if the graphics appear there.
Mic doesn't work
check the manual. also go to their website for answers. look at the back of the machine and see if it does have a connection to hook it up to speakers. also, if you have a mic see if it has a on/off switch. you could have it in the off position and not on; also, check the machine to see if it has a knob to turn to mic.
Karaoke Machine - words are overlapping/jumping
The Sining Machine #SMG-301 has a problem with not playing because of the word 'DOOR' coming up on the readout. I've checked the door/Tray to make sure that it was closed and when you open up the tray/door to put or take out another disk the word that comes up on the readout is not DOOR it's OPEAN! Any suggestions?
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
