20 Most Recent Symantec Winfax Pro 10.03 (winfax10.03) for PC Questions & Answers
Yes you could send a Fax through Internet.You could refer many Sites :-
http://www.passtheshareware.com/fax.htm
http://faxzero.com/
You could Google the same, as there are many sites.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Symantec Winfax... | Answered on Jan 02, 2016
Hey!
If the uninstallation through Programs and Features doesn't work for you, follow the instructions here. Afterwards, download and run Norton Removal Tool...
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Symantec Winfax... | Answered on Jun 04, 2011
Hello, There are two things you might want to check. First: make sure you have more than 50MB available on your hard drive for the installation. If not, try to free up more disk space and try the installation again. If the installation went half way through, you might need to manually uninstall and reinstall. Second: If the installation process immediately failed when started and you have lot of disk space available on hard drive, you might want to copy entire installation CD into your hard drive and start the installation from hard drive (not from CD) Let me know if I can further help.
Thanks
Symantec Winfax... | Answered on May 04, 2011
Good Day!
try to Reset the settings of your Winfax, maybe you change it.
Thanks and God Bless!
Symantec Winfax... | Answered on Apr 20, 2011
fax modem class 1, class 2, or class 2.0
fax line (analog regular phone line)
windows xp or earlier releases of Windows
http://www.getfaxing.com/winfax
Symantec Winfax... | Answered on Feb 23, 2011
Select the event in WinFax, right-click, properties.
This will give you details of the fax.
The log will also show you time sent, and total sending time.
http://www.getfaxing.com/forums
This message is normal, because it is not compatible with 64 bit versions of Windows.
If you are using Windows 7 x64 (or 32 bit), it will not work.
You may want to upgrade WinFax here: http://www.getfaxing.com/faxtalk
Please post the full error message and more details regarding the problem.
click start all programs accessories systems tools task scheduler you will be able to set up your requested event at a specific time and date
hope this helps
dont forget to vote
Symantec Winfax... | Answered on Feb 15, 2011
What is the error message when you attempt to connect to the Host with the client?
Symantec Winfax... | Answered on Nov 19, 2010
Yes it should because Microsoft has made its' operating system backwards compatible with all programs prior to it's development. However some hardware devices might not. Therefore you would have to go to their website to download an update. You can also check the Symantec website to verify this application will work with Windows 7.
Symantec Winfax... | Answered on Oct 25, 2010
are you on win 7?
write back, i have included the below in case you fall into this cattegory
Don’t get duped into buying a counterfeit WinFax PRO 10 CD ROM. Here is how you can tell the difference from a “real” CD ROM and the obvious fakes. If you purchased your Symantec WinFax PRO with a box and manual, chances are it is the genuine item. If you purchased a “loose” CD ROM, usually referred as “OEM”, then you should check for the following:
How to detect a counterfeit WinFax PRO 10 CD ROM
  • Symantec never included the actual revision of WinFax PRO 10 (10.01,10.02 or 10.03) on the CD ROM. So, if your WinFax PRO CD ROM says “WinFax PRO 10.03′ its a fake. All genuine WinFax PRO 10 cd’s contain the heading ”WinFax PRO 10.0′
  • If you see text with “winFAX” or “Live Update” anywhere on the CD its a fake. The official Symantec trademarks are ”WinFax” and “LiveUpdate”, no other variations of this text should appear on the CD ROM.
  • Failure to capitalize ”symantec” and “corporation”.
  • An “All rights resverd” spelling error, or other spelling errors.
  • Incorrect font used for WinFax PRO and Symantec logo. The current Symantec logo is consistant across all software they produce.
  • Silver portion of CD is a (dull) matte finish, on the real CD it is relective (mirror surface).
  • To determine if the CD is brand new and sealed – geniune WinFax PRO 10 CD’s come in a white envelope sleeve that are sealed with a sticker that may have one or more of the following: a bar code, a Symantec 5 or 6 digit product code, a brief license agreement.
  • In most cases, manufacturer information is printed on the inner rim of the CD ROM of genuine CD’s. This is usually missing on a counterfeit.
  • Update patch 10.04 is not included on genuine CD ROMs. Any CD that contains the patch update to 10.04 is a counterfeit
Symantec Winfax... | Answered on Jul 28, 2010
print menu from what application?
Microsoft Word?
http://www.getfaxing.com/products.htm
Download WinFax Macro for Microsoft Word
Symantec Winfax... | Answered on Apr 12, 2010
Symantec Winfax Pro 10.03 (winfax10.03) for PC Logo
Popular Tags
65 questions posted
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Symantec Computers & Internet
Most Popular Question
symantec winfax 10 03 cannot share
  • Computers & Internet
