20 Most Recent Korg D3200 Studio Package Questions & Answers
The import needs to happen from a computer (or a CD-RW) >D3200, not from a flash drive or backup drive.
Korg D3200... | Answered on Apr 29, 2016
do you have the owner's manual if not download it-there are /were you tube videos for what your trying to do- they helped me alot - when you plug your guitar into the guitar jack on channel 1 you can't use the xlr input 1at the same time in addition be careful not to blow the audio system there are no replacement parts for this system
Korg D3200... | Answered on Apr 08, 2014
yes- check out the m-auduo studiophile speakers & there are other brands that are better depending on your wallet.
You need an application to recover your deleted files.
Some of these data recovery applications are free and does not cost you a dime.
Others you will have to purchase.
Here is a YouTube video that show you how to recover your deleted files.
http://www.youtube.com/watch?v=ndLXZbqQRAY
Good luck
Korg D3200... | Answered on Sep 03, 2013
That sounds like an excessive repair bill. It sounds like it was a failure in the power supply. Read the repair order and add that info here.
Korg D3200... | Answered on Aug 20, 2013
Please try to power reset the unit. Pull out all power cables and wait about 20min.
Best of Luck
Korg D3200... | Answered on Jul 20, 2013
Korg is a great company and when you contact them they will help you. They can tell you how to get the CD and/or how to download and burn it to your own CD. then you can boot up the device
Korg D3200... | Answered on Feb 27, 2012
Hello
Can you explain how did you adjust the space on your computer?
Korg D3200... | Answered on Sep 08, 2011
Somehow proper save and shutdown was not done. You said the magic word PANIC... That is a deadly word in this situation. So first thing like for lost files on a PC is to look around... carefully. LIKELY the files are still there, just under a different folder or imbeded in another project. These systems do a pretty good job of not letting one clobber their files without confirming AS LONG AS proper shutdown procedure is used or power doesn't fail. The five tracks you might have forgotten to save...but the other should be there.
Korg D3200... | Answered on May 20, 2011
If the buttons are just sticking at their sides in the panel, lube with a tiny bit of CRC 226 on a Q tip. Get the CRC226 at Home Depot in the electrical dept. If the button mechanisms have failed or plastic hinges have broken then replacement is only option. Losing 4 of these to same problem is RIDICULOUS... time to change brands.
Korg D3200... | Answered on May 02, 2011
Unless you are electronically adept and have certain tools I would NOT attempt this yourself. You could damage the circuit board causing great repair expense.
Korg D3200... | Answered on Feb 24, 2011
Here is a link to the manual:http://img3.musiciansfriend.com/dbase/pdf/man/m_242061.pdf Just remember the mentioned site has lots of support for other brands too.
Korg D3200... | Answered on Oct 22, 2010
Go through the manual
http://media.zzounds.com/media/D3200_E1-0b1b188ba8292cca3f022268d3632c1f.pdf
Korg D3200... | Answered on Jun 09, 2010
hi
you will find your solution from folowing site
http://www.zzounds.com/item--KORD3200
Korg D3200 Studio Package Logo
Popular Tags
21 questions posted
Top Korg Music Experts
Michial Gueffroy
Poul Brinchs Larsen
tmaree
tmaree
Are you a Korg Music Expert? Answer questions, earn points and help others
View Most Popular
Korg Music
  • Korg Music
Most Popular Question
importing files into korg d3200
  • Music
