20 Most Recent
Behringer Europower Pmp5000 Powered Mixer Pmp5000 Questions & Answers
None of the channels work.
If you plug into the PA input or inserts of this unit, that DISCONNECTS all the mixing channels within this unit and none in this unit will work. That is how it is supposed to work.
If you wish to use another mixer as well as the channels in this, I suggest you run the other mixer into one of the stereo channel inputs OR the CD inputs, although the CD are NOT balanced inouts and subject to higher noise level.
11/8/2021 6:46:02 PM •
Behringer...
Answered
on Nov 08, 2021
One side of my europower
What is up is one of the two power amps is blown... I know this problem... It is USUALLY the rearmost channel which goes to the left Speakon faacing the back. Weak insulation between layers of the multilayer circuit board arcs and fries three transistors and a diode and sometimes a few more components. It takes a lot of skill to restore the module and is beyond most repair shops. A whole new module costs about $155 from Full Compass. The amp is an HCA2400 module, but you MAY need the Behringer part number to order it from Full Compass. Also please read my tip on Fixya for PMP mixers regarding the hazard when using 1/4 inch plugs from the Speakon connectors... the Channel A sleeve is the "hot", not the tip and if you ground the sleeve, goodbye channel A...
11/1/2021 4:27:44 PM •
Behringer...
Answered
on Nov 01, 2021
Need part # for the Program Push Button Control
You will have to call Behringer in Woodinville WA to get the Behringer part number. Their phone is:
(425) 939-3200
With the number plus an incident number that Behringer will give you, you then call FullCompass who is the parts distributor... Then, unless they have it in stock, plan to wait a long time to get the part. FullCompass phone:
800-356-5844
Lots of luck... I have waited for three months for parts.
11/1/2021 1:29:02 AM •
Behringer...
Answered
on Nov 01, 2021
How to wire up outboard effects, poweramps to mixer. Out to sub, mains, monitors each with own poweramp, and several outboard effects, eq's, comp/lim/gate, sonic maximizer, quadraverb, crossover.
I'd need to know what mixer you have, to know if there is a [line out] connection socket and an [internal amp in] connection socket.
"each with own poweramp" I presume means the ep1500's and NOT that the speakers are active (ie containing amps)
***If any of your speakers are active, ask the question again, with more detail.***
So if all your speakers are passive, I offer the following.
I assume there is [effect send] and [effect return] on the mixer
effect send>quadraverb>effect return
mixer line out > eq > compressor > sonic maximizer > crossover
sub output of crossover> amp > sub
high output of crossover to mixer's internal amp input
mixer's speaker output > main speakers
monitor output > other side of eq (>other side of compressor if desired, but use sparingly ) > other side of sonic max if it is true stereo , otherwise skip > amp > monitors
If your mixer doesn't have an input to its internal amp, we are "back to the drawing board"
With questions like this it pays to give as much detail as possible; model and make of each component etc
I have done my best with the the info you have provided.
Don't feed amp outputs into powered speakers
10/25/2017 3:07:57 PM •
Behringer...
Answered
on Oct 25, 2017
PMP Mixers hazard
When using Speakon adapter cables with 1/4 inch plugs, the sleeve of channel A is the hot and not the tip of the plug. Inadvertent shorting of this to ground can blow that channel of the amp.
2/16/2015 3:50:47 AM •
Behringer...
Answered
on Feb 16, 2015
No sound coming out on both r and l channel
Oops! Smoke from on of those is not unusual, as behringer is notorious for bad solder joints and BAD Power supplies. Anyhow the amplifiers are "most likely" OK. but your powersupply is shot. My PMH 3000 did the exact same thing. And here is the bad news. Behringer is also notorious for the lack of assistance in case of problems and will advice you to have the unit repaired at an approved service point. If however you are ok with electronics you can have a go yourself, manuals are few and (very) far between. I have some diagrams and stuff, so if you need some sing out. I have 2, MX 3282A mixers, nothing but trouble! Sorry I can't help you any further, Good luck.
8/14/2014 8:48:21 PM •
Behringer...
Answered
on Aug 14, 2014
What are the Behringer BXL 1800A most common problems?
If you overload them the output MOSFETs fry and tend to take the circuit board and a few resistors out. They are fixable but it's a pain hat the board fries. The tracks need building up with wire so they can carry the necessary current (or any once they fry). Apart from that they are a decent Amp for little bucks and sound pretty good. They'll need micing for anything but smaller venues but the functions are really useful in getting a good sound for the buck.
5/19/2014 5:48:51 AM •
Behringer...
Answered
on May 19, 2014
How do i connect focusrite to europowered pmp4000
You don't say what item of Focusrite equipment you are trying to connect or for what purpose. Most focusrite stuff has jacks with analog outputs for each channel that can be used into the line ins on the mixer and jack/xlr combos that can be used to take a signal to the focusrite box. Then you get the firewire side for the PC and digital outputs as well which will not be of use with your mixer.
4/15/2014 10:39:35 AM •
Behringer...
Answered
on Apr 15, 2014
I have a pmp 5000 and i run crown power amps...i
Assuming you have not got the fx1/2 to mon turned right down it would seem likely that this has failed which would be about the only thing that would stop fx to mon if all else is working. You do not describe the distortion to the mains but if it is related to the fx then this would point to the same thing, a failed pot probably. These are a total nightmare to replace although the part is dirt cheap. Allow your self several hours if you think it is worthwhile. Behringer (and some other) mixers are now made in such a way as to be almost unrepairable using a single smt board that requires total disassembly of the unit to replace even wearing parts (excluded by the warranty). I would suggest replacing the mixer with a new one or a decent second hand one.
2/12/2014 8:14:06 AM •
Behringer...
Answered
on Feb 12, 2014
