20 Most Recent
Jugs Baseball 101 Pitching Machine Questions & Answers
Jugs 101 pitching machine , bottom motor will not
Just had this happen on my machine. Opened up the control box and found center disc capcitor was loose from cold solder joint. However we also found the hot lead for the motor at the wiring block on the circuit board had a cracked solder joint. Simply reheated with solder iron and applied little extra solder and it working again.
Hi we need a manual
Hi Linda, i have the same 1983 Travelaire motorhome Econoline F-350 26ft and are in search of the Shop/owners manual ... Do you know where to find one ?
I am located in BC Canada
Reg 250-379-2971
[email protected] if you can contact me ?
How can I maintain my pool table at top condition?
In
order to maintain the condition of your table and prolong its lifetime you
should avoid eating above the table, putting drinks of ash trends on the sides
of the table, and generally try not to harm the cloth with the cue. In addition
you can clean and vacuum the table from the outside once a month, this Is what
I'm doing to my table.
What is the price range of a quality foosball table?
Good quality and long-lasting table start at
about $600. In this case, like in many others, the more you pay, the better
quality you will get. Make sure that you're buying a known brand and compare
prices first, before you buy. It is also recommended to read some reviews about
a table or tables that you like.
How to repair tent trailer roof
Go to an auto parts store and buy a fiberglass kit. Resin, hardener and cloth. Clean and rough the area. apply a coating of mixed resin, then a layer of cloth. Let it dry and repeat a couple of times. After you are satisfied with that get a gallon of Elastomeric, you will find it at Lowes/Home depot. Clean the entire top and apply 2 coats with a brush or roller about 24 hours apart. No rain or moisture for a couple of days. Project complete, water proof roof.
