20 Most Recent
Weedeater 19 in 25cc Gas Hedge Trimmer Questions & Answers
My 10 year old weedeater
I would check for spark and check the fuel lines, especially if fuel is left in it. Also if fuel left in you will have to empty the lines and carburetor or pull it enough to clear. Another thing to consider is that if fuel was left in it that the carburetor may need a rebuild, replacing the diaphrams.
I hope this is helpful for you.
TRIMMER STOPS RUNNING AFTER A COUPLE OF MINUTES
Check the air filter isn't dirty.
If the fuel line is a flexible type which moves around
inside the tank, check it is able to move freely because if you are
cutting at awkward angles, the end of the line can end up above the
surface of the fuel, **** in air and airlock the line.
The fuel lines may have become airlocked.This can happen if the tank is
run dry. If the trimmer has a primer bulb, alternatively press it
several times and then try to pull start the engine with choke on.
Repeat this several times. The primer bulb should feel spongy and fill
with fuel.
You can eliminate
this as the problem by fully filling the tank.
Check whether there
is a one way check valve on the tank. This vents air into the tank as
the fuel leaves for the carburettor. Sometimes particles of dirt can get
stuck in this.
Black& Decker grasshog electric weedeater GH600.. 2007.Need advise removing the guard. No screw, but 3 springy tabs. I don't have 3 hands to move them at the same time
Removing the guard on your Black & Decker Grasshog electric weedeater GH600 can be tricky without three hands, but here's a method you can try:
1. Use a flathead screwdriver or a similar tool to depress one of the springy tabs while holding it down.
2. While holding the first tab down, use a second tool (another flathead screwdriver, a pair of pliers, etc.) to depress a second tab.
3. Once you have two tabs depressed, you should be able to use your free hand to push or pull the guard away from the trimmer.
4. If needed, use the same method to depress the third tab and completely remove the guard.
Alternatively, you might ask someone to assist you by holding down the tabs while you remove the guard. If you're still having trouble, refer to the user manual or contact Black & Decker customer support for further assistance.
My Hart 40V Electric weedeater won't start up with either charged battery
The first thing to check is the connections between the battery and your weedeater. Make sure that all connections are secure and there isn't any corrosion or dirt build up on the contacts. Additionally, you may want to try cleaning out the spark plug and checking for obstructions in the fuel tank or line. If these checks don't lead to a resolution, it may be worth contacting a service tech to further diagnose the issue.
Why is spark plug smell like it is burning
There can be a few reasons.
1. The seal on the spark plug is not sealing properly and the oil from the two stroke oil is leaking out and burning. If it is leaking from the centre of the plug, the ceramic core is broken. They are cheap enough to buy and easy to repair.
2. The cylinder head gasket is leaking a bit and burning oil off.
Make sure any filters on the fan(?) or the air filter are clean as it sounds like it might be overheating as well.
full make and model in all questions please.
