20 Most Recent
Homelite Carburetor Trimmer Blower Mightylite Versatool Questions & Answers
Wont prime up
I have seen a couple of different things cause this... Are the fuel lines hooked up and not split and fuel filter routed right in tank.(hanging freely touching bottom of tank lying flat) next if your carb has adj. screws H &L I have seen when the H is cranked snug (lean) that primer won't work right. Last but not least your Needle inlet valve is stuck shut and or the fuel pump diaphram little tabs are not sealing off chambers in carb on fuel pump side. make sure your fuel lines are properly hooked up to the right spots. when you push primer bulb it should squirt gas into the fuel tank, then when you release it ,it should draw fuel from the tank through the filter and thru the carb and then out to tank.
11/18/2011 1:58:42 AM •
Homelite...
Answered
on Nov 18, 2011
Plastic primer cap perished can
Hello wesandfran, yes, that is a very common machine and you may even find the part at places like Home Depot.
I hope this helps you,
Good luck my friend!
1/17/2011 6:41:38 AM •
Homelite...
Answered
on Jan 17, 2011
I can not get it started unless I pull the plug
You may have a dirty carburetor. this can be tough to fix as the openings are so small. Also you may have a dirty fuel filter. (often located in the gas tank) also does it have a priming bulb? Trying freash gas is always a good idea.
11/27/2010 10:42:13 PM •
Homelite...
Answered
on Nov 27, 2010
Need a fuel line diagram for my Homelite vac attack 2 model UT09834
You should have 2 lined coming from tank. A return and feed. Normally the return is the lowest positioned outlet on the carb, and the feed is at the top. When pumping the purge bulb take the gas cap off tank, and you should see fuel being returned to the tank from the return line. If not, switch the lines on carb. If still not returning fuel to the tank, you will need to pull the carb and inspect the metering and fuel pump diaphrams.
What is the spark plug gap for a homelite 2700psi pressure washer with champion eco 322
The recommended spark plug gap for a Homelite 2700 PSI pressure washer with a Champion Eco 322 spark plug is 0.030 inches.
but in my opinion, It's always best to consult the owner's manual or contact the manufacturer for the most accurate and up-to-date information regarding the proper spark plug gap for your specific pressure washer model.
good luck
What gas does a Homelite 16 " Ranger chain saw use
The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle engine oil, and the manufacturer recommends the use of a two-cycle oil that contains fuel stabilizer to keep the mixture fresh if you are not using it immediately.
