20 Most Recent
Champion International Champion Riding Mower Lawn Tractor Cover Questions & Answers
I have a cub cadet lt1045 that the belt comes off all the time
The stock settings on this tractor are awful, I ended up chopping the spring down and then using a propane torch I heated it up to make another bend at the end, this added tension. I then also had to adjust the angle that the tensioning bogey, or pulley, spun at. I believe I bent the piece of flatbar metal it rides on to change the angle so that it is lined up better with the p.t.o pulley. Loooots of trial and error.
If you have the snowplow accessory as well I found that I had to tighten the tension all the way on that as well to stop it from folding under a minor amount of snow, now I can take a run at a drift and push it without the blade caving under.
8/9/2010 10:41:54 PM •
Champion...
Answered
on Aug 09, 2010
Case 580C Backhoe starting problems
either you have a short in the wiring, a loose connection somewhere or a bad starter, check for broken wires first and clean connections. then try the starter see if it turns with a direct connection to another battery
8/18/2009 10:23:17 AM •
Champion...
Answered
on Aug 18, 2009
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
2 days ago
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
