Toshiba TLP-B2 Multimedia Projector
Problems with Toshiba TLP-B2 Multimedia Projector?
Troubleshooting and Support
Solved Problems for Toshiba TLP-B2 Multimedia Projector RSS Feed Post a New Problem
projector bulb replacement
If I get a dlp or lcd projector should I plan on paying $400 or $500 every few months for a replacement bulb?...
4 Solutions
intermittent start of bulb
i was thinking this is a ballast problem. it won't hurt to take the top of the back of the tv to repair it.
1 Solution
Cannon Projector LX-V5
We are facing problem with our projector. It is all pink in colour now. kindly solve the problem as we have a...
1 Solution
Projector
Got a Saville NPX3000 projector. Powers up ok and tells me it's autosearching but won't display my computer. I got no...
1 Solution
vt45 projector turns off without notice.
The projector turns off while in use. It doesn't really needto be "too hot". It may be in the first few...
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
Remote control for Canon LV X6 Projector
I cannot seem to get the remote control to work for the projector. I'm trying to use a PowerPoint Presentation and the...
1 Solution
Unsolved Support Problems
Unsolved Problems for Toshiba TLP-B2 Multimedia Projector RSS Feed Post a New Problem
Projector won't accept composite but works...
Strange one - I have had my TV connected to the composite (video) input of the 5700 and it worked fine. yesterday when i...
Post a Solution
Replacement BULB not lamp cost less
I found an old Toshiba TLP-B2 projector. I know at the very least the bulb is burnt out but it could have other...
Post a Solution
Toshiba TLP-B2 Ultra Lamp not lighting
The lamp flashes and then goes out, the indicators then after awhile go out. It is suppose to be a new lamp in it. What...
Post a Solution
Temp light falsely indicating overheating
When I power up the projector it starts normally and works for 20 seconds. At that point it then turns off the bulb and...
Post a Solution
Tips & Tricks
Post a New Tip
WikiManual
Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Specifications
Key Features
TypeLCD Projector
Form FactorPortable
Display TechnologyTFT Active Matrix
Image Brightness1000 ANSI lumens
Max Resolution (Native)1024 x 768
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)25 in. - 250 in.
Screen Distance3.77 ft. - 34.55 ft.
Color Support24-bit (16.7M colors)
Technical Features
Audio OutputSpeaker(s)
Lamp
Lamp TypeUHP
Standards
Analog Video FormatNTSC · PAL · SECAM
Dimensions
Depth10.71 in.
Height2.80 in.
Width9.13 in.
Weight5.73 lb.
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
Loading problems.
Top Experts
Ask Me
techman Guru
2 solutions
Ask Me
windman Wiz
1 solutions
Ask Me
coolguy00 Wiz
1 solutions
Repair Service
Find Multimedia Pro. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
