20 Most Recent
Waterway Executive 48 Spa Pump 2hp 1spd 2" 34108301 () Questions & Answers
Hi , my executive 48 pump is leaking water at the
The pump seal is the problem and it can lead to bearing damage if not caught soon enough. The seal used in the waterway pump is not as easy as most seals to replace. You are better off to have it done at a pump repair shop or pool store than to tackle it yourself unless you are familiar with this seal and have the tools to fix it. A repair bill would likely be under $75 for a seal replacement at a shop and they can replace the bearings if necessary.
John
8/10/2012 4:51:16 AM •
Waterway...
Answered
on Aug 10, 2012
How do i remove pump from motor to repair or
Thank you for posting your question here on Fixya.com.
Remove the front cover on the pump and the shaft cover on the opposite end (back of the motor). Once the covers are off you can lock the motor shaft at one end using a screwdriver or wrench and then turn off the impeller counter-clockwise. Once the impeller is off you can remove the rest of the pump by loosening the 4 thru-bolts in the motor.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
12/2/2010 5:40:10 PM •
Waterway...
Answered
on Dec 02, 2010
