20 Most Recent
Pride Mobility Products Pride Jazzy 1650 Questions & Answers
MY NOKIA 1650 MOBILE PHONE IS LOCK BY SECURITY
12345 is the default code and if you have changed it then try remebering the password.
and if you cannot remember the password then try this on your risk
*#7328748263373738#
it will reset all the security codes to 12345.
Pride elite traveller 4 a knock when driven coming
hi,
Sounds to me like the worm drive is slipping , this can happen when the worm drive small bearing is worn,
If you do take it a part , please take great care, the shaft from the motor will have a worm drive, two bearings on the worm drive,
Try to move the shaft within the bearings, I paid £10 for replacement bearings.
Please give me a update.
Regards
GeWiz.
Lights work no power
Check you're freewheel lever if its in freewheel u have to take the key out engage lever & put key back in. Also if u have left the key on for more than twenty minutes the circuit will shut down only the light will work. take key out for 5 minutes then put it back it should work unless it's another problem good luck
