FixYa.com
Toshiba TDP-SW80U Multimedia Projector
All Products > Toshiba > Multimedia Projectors
Problems with Toshiba TDP-SW80U Multimedia Projector?
Search inside Toshiba TDP-SW80U Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for Toshiba TDP-SW80U Multimedia Projector RSS Feed Post a New Problem
How do I redirect the output of my PC...
How do I redirect the output of my PC laptop to the projector?
1 Solution
Projection Problem with Toshiba TLP 261
When the projector is turned on, it displays the default screen. In the lower left corner the display is red. Adjusting...
1 Solution
Epson EMP-82e locked out
One of our staff turned off the projectors power. He then proceeded to input the wrong security code and the projector...
1 Solution
Connecting Sky TV to my projector
I am finding it hard to connect my sky tv to my projector, which cable do i need.
2 Solutions
green tint
I just purchased an epson powerlight s1. All the highlights are green. I tried adjusting the color and tint, but nothing...
1 Solution
my problem is that the Image is not...
my problem is that the Image is not stable, on my projector, any suggestions?
1 Solution
CONNECT CABLE TO MY PROJECTOR
HOW DO I HOOK MY CABLE UP TO MY MITSUBISHI DLP PROJECTOR MODEL HC1500
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness2000 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)24.6 in. - 246 in.
Screen Distance3.9 ft. - 32.8 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1600 x 1200 (UXGA)
Synchronization Range Horizontal15 - 93 kHz
Synchronization Range Vertical50 - 85 Hz
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack · RCA Jack
Operation Noise35 dB
Interfaces
InterfaceMini DIN 8-pin
Video Input4 Pin - Mini DIN (S-Video) · 15 pin D-Sub VGA x 2 · Composite Video · Component Video
Lamp
Lamp TypeUHP
Light Source Power200W UHP
Other Features
Special FeaturesKeystone Correction
Speakers Output1 W
Networking
Networking CapabilitiesWireless Networking
Standards
Analog Video FormatNTSC · PAL · SECAM
HDTV Formats720p · 1080i · 480p · 576p · 480i · 576i
Warranty
Warranty2 Years, 90 Days On Lamp
Dimensions
Depth10.8 in.
Height4 in.
Width11.7 in.
Weight6.4 lb.
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
