20 Most Recent
Shoprider Sprinter XL4 Deluxe 4 Wheel Scooter Questions & Answers
My scooter
I don't know the answer but I will take a guess.
These mobility scooters use a lot of electronics. Switch mode power supplies are a way of controlling a dc motor more efficiently than with rheostats or the solid state equivalent, large power transistors. There are also electronics and relays to change the polarity for reversing and further electronics to prevent the scooter being able to reverse as fast as it goes forward.
When two motors are used they could share some of the same electronics or the electronics could be duplicated for each motor. While this would provide a fairly basic control there are some considerations, namely the front wheels travel further than the back when going around corners and during this the rear motor will be pushing the front motor and it will be acting as a generator.
The circuitry has a lot to do as apart from controlling each motor it must synchronise them so they consistently produce the same effort and at the same time allow the front motor to speed up slightly when cornering so the rear motor doesn't have to push it.
Clearly it is a requirement the two motors must talk to each other via the circuitry. While it would be better that each motor provides torque feedback, such a system would be complex and expensive and so it is more likely the current each motor consumes is monitored and synchronised via intelligent circuitry.
From your description I suspect the problem is a breakdown in communication between the two motors or the current monitoring or the synchronisation circuitry.
Usually scooter manufacturers assemble all the circuitry on a single board and seem reluctant to offer a checking and repair service, preferring instead to sell complete boards at inflated prices.
Double checking all the connections might produce results but the chances are you won't be able to go much further without a complete circuit diagram.
9/7/2016 8:19:44 AM •
Shoprider...
Answered
on Sep 07, 2016
I have the Shoprider Delux scooter.I brought it
Yvonne,
When you say that you put in a new battery, I hope you mean new batteries. This particular scooter takes 2 batteries and just changing one will leave the remaining one in poor condition. Make sure that you have replaced the batteries with the correct size and type. This scooter takes 2, 40 amp hour batteries. Sealed gel AGM batteries are preferred. The batteries should have the number 40 on them with a date code. You need new, fresh batteries to have them work properly. A date code tag of A1 indicates the A month(1st month) or January of 2011 (1 is for 2011). If you are not sure of the battery condition a local shop can load test them for you.
There is a possibility with a 5 year old scooter that a worn motor/brake will cause excessive current draw and drain your batteries. A qualified technician can determine this for you with a service call.
Hope this helps.
2/21/2015 7:58:42 AM •
Shoprider...
Answered
on Feb 21, 2015
Push button to turn on and it just flashes and beeps
Hello,depending on what the series of beeps are & on whether it is a scooter or wheelchair.Then you can work out the problem.If you are trying to repair yourself,"please take a pic of anything before you touch on your mobile say,for relaying back to".Have a look at:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772,Download as a PDF File to view.Hope this was of help,have a nice day.Colin
What does the ac3 mean at the end of the code on the shoprider rascal controller unit
that's part of the serial no, what import is the first part
for example modern types
CA-AC2-110(A2)
means it a 110amp controller used on a Cadiz , some Rascal's .
C7-AC2-40
means it a 40 amp controller used on the smaller scooters such as the Wispa ..
C5-HFPC-888A .. older type
888 is the model no used by shoprider
normally a 70 amp rated controller used on the shoprider sovereign mobility scooters
regards
