FixYa.com
Toshiba TDP-S81U Multimedia Projector
All Products > Toshiba > Multimedia Projectors
Problems with Toshiba TDP-S81U Multimedia Projector?
Search inside Toshiba TDP-S81U Multimedia Projector Knowledgebase
Troubleshooting and Support
Solved Problems for Toshiba TDP-S81U Multimedia Projector RSS Feed Post a New Problem
How do I adjust the frequency for an...
How do I adjust the frequency for an external monitor (projector)?
1 Solution
optoma projector
We are having problems with our projector. The screen (or light bulb) flickers. We have had it just a little over a year...
1 Solution
CONNECT CABLE TO MY PROJECTOR
HOW DO I HOOK MY CABLE UP TO MY MITSUBISHI DLP PROJECTOR MODEL HC1500
1 Solution
LCD shutting off automatically
I use a Benq LCD projector to give powerpoint presentations. Lately the projector shuts down shortly after powering up....
1 Solution
paint your website area by giving...
how can you paint your website area by giving coordinates ?
1 Solution
In Focus X2 projector won't display...
In Focus X2 projector won't display welcome screen. It turns on, the fan goes on too and the green light is steady. I...
1 Solution
White vertical line in the center of...
We have had our X2 for about 3.5 years and not changed the bulb out. Within the last two weeks, a vwrtical white line,...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
PlatformPC · Mac
TypeDLP Projector
Form FactorPortable
Display TechnologyDLP
Image Brightness2000 ANSI lumens
Contrast Ratio2000:1
Max Resolution (Native)800 x 600
Image Aspect Ratio4:3 (Standard)
Image Size (Diagonal)24.6 in. - 246 in.
Screen Distance3.9 ft. - 32.8 ft.
Color Support24-bit (16.7M colors)
Max Resolution (Interpolated)1600 x 1200 (UXGA)
Synchronization Range Horizontal15 - 93 kHz
Synchronization Range Vertical50 - 85 Hz
Technical Features
Audio OutputSpeaker(s) · 3.5 mm Mini Jack
Operation Noise35 dB
Interfaces
InterfaceRS232C (mini DIN-8 pin)
Video Input4 Pin - Mini DIN (S-Video) · 15 pin D-Sub VGA x 2 · Composite Video · Component Video
Lamp
Lamp TypeUHP
Light Source Power200W UHP
Other Features
Special FeaturesKeystone Correction
Speakers Output1 W
Standards
Analog Video FormatNTSC · PAL · SECAM
HDTV Formats720p · 1080i · 480p · 576p · 480i · 576i
Dimensions
Depth10.8 in.
Height4 in.
Width15.1 in.
Weight8.2 lb.
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
