lampThe picture is getting very dark and flickering.The lamp only has 740 hrs on it. Is that the problem?
1 Solution
fuzzy imagesI use my projector to reflect on the Smartboard in my classroom. It is now projecting some fuzzy colors in the bottom...
1 Solution
Vertical Green LinesI have vertical green lines to the right of some images in my Epson Powerlite5000XB. Is it possible for me to open it up...
1 Solution
View All
Specifications
Key Features
Image Brightness750 ANSI lumens
Max Resolution (Native)854x480 Image Aspect Ratio4:3 (Standard) · 16:9 (Wide Screen) Image Size (Diagonal)24.02 in. - 289.37 in. Screen Distance3.94 ft. - 39.37 ft. Color Support24-bit (16.7M colors) Max Resolution (Interpolated)1024 x 768 (XGA) Synchronization Range Horizontal15 - 93 kHz Synchronization Range Vertical50 - 85 Hz Video ModesStandard · Cinema
Technical Features
Interfaces
Video Input15 Pin D-Sub VGA · 4 Pin - Mini DIN (S-Video) · DVI-D · Composite Video · Component Video
Lamp
Light Source Life2000 Hours
Other Features
Special FeaturesKeystone Correction · Film Mode Projection MethodRear · Front · Ceiling
Standards
Analog Video FormatNTSC · PAL · SECAM HDTV Formats720p · 1080i · 480p · 480i · 576i
Dimensions
Toshiba Contact Information
Main support number800-457-7777
Sponsored Links
