20 Most Recent
Weiser Lock Powerbolt Electronic Deadbolt Ed1460 X3 Kd V 6Way Powerbolt Questions & Answers
On my house door lock, I recharged my batterie and now the lock wont work
When it comes to rechargeable batteries there is an unspoken rule to not use them for smoke detectors, clocks, and menial electronics. Only use them for flashlights and stereo systems that you carry on your shoulder. :) All you can do is make sure that the batteries are touching all the terminals and that they are facing the right way.
How do I enter new code?
www.
weiserlock.com/.../
electronics/smart...
Translate this page
Weiser Lock25605-02 Weiser SmartCode Manual. Program. Button .... Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into .... anyone withaccess to the power board can change these codes, you must restrict access ...technical means, or evaded by entry elsewhere on the property. No lock.
I installed a weiser smartcode lockset and the
2 important things which may seem dumb but solved my problem:
- Make sure that once everything is in place, you hold the lock button before inserting battery pack (and keep holding the lock button) until you hear 2 beeps. The latch should come and go.
- Last but not least, make sure you put NEW batteries in... I had old batteries and when i tried it seemed like is was working but could not finish the door direction finding sequence stated above. Make sure they are new and it should work!
Dead bolt too stiff
If you mean it feels like it's dragging when extended, it probably need to the screws holding the inside portion of the lock to the outside portion and realign those two while actuating the lock to find where it operates freely.
