20 Most Recent Day-Timer Intermatic Ei600c Digital 7 Day Timer 20 Amp 24277v Questions & Answers
How do I reset the intermatic EI400 light timer
Copy following link to identify Ei400 series programmable countdown timer and download possible manual:http://waterheatertimer.org/Intermatic-timers-and-manuals.html#Ei200Hold down ON/OFF button and fully press-and-release small round reset button using paper clip.Keep holding ON/OFF button until display changesThis timer uses CR2 battery installed in tray below the buttons.Reset timer after installing new battery.If functionality is not restored after new battery install and reset, then timer has gone bad.This timer has 1 year limited warranty through Intermatic for defects in workmanship.Ei400 can be wired for single-pole or 3-way.Timer requires no neutral wire since battery operates the timer and relay circuit If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
11/23/2012 7:31:19 AM • Day-Timer... • Answered on Nov 23, 2012
2answers
Lost my instructions for intermatic
EI600 is a heavy duty 20Amp in-wall timer that is battery operated, and can replace single-pole or 3-way switches.
Intermatic page
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%207-day%20astro%20time%20switches.aspx
EI600 manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei600c%20-%20english.ashx
8/11/2012 9:22:10 AM • Day-Timer... • Answered on Aug 11, 2012
Is this okay to use with CFLs. Cannot find any
A timer turns the circuit on-and-off just like a switch
Anything a switch can turn on-off, a timer can turn on-off
Things get complicated when using a dimmer, but not a timer
2/27/2011 4:03:25 AM • Day-Timer... • Answered on Feb 27, 2011
Lost instructions!
You can get the manual on the link below. If this is not you timer please give the correct make and model #.
Good Luck
11/12/2010 1:13:10 AM • Day-Timer... • Answered on Nov 12, 2010
2answers
How to program utilitech 1
Do you have the Utilitec number?
Add a comment with description of timer I can help.
I own several Utilitec timers.
Following link shows programming for 4 different Utilitec timers;
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
12/6/2015 2:45:30 PM • Day-Timer... • Answered on Dec 06, 2015
INSTRUCTIONS FOR SETTING HPM718/2 MODEL
817? http://waterheatertimer.org/Woods-timers-and-manuals.html#HPM Gene h If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
12/18/2013 6:03:48 AM • Day-Timer... • Answered on Dec 18, 2013
0answers
Utilitec 0144506
Be the first to answer 10/21/2013 4:27:59 PM • Day-Timer... • Posted on Oct 21, 2013Be the first to answer
3answers
How do you program the utilitech 1-outlet daily
How do you program the Utilitech Outdoor 6-outlet Stake Timer
5/7/2012 4:55:54 AM • Day-Timer... • Answered on May 07, 2012
I have a one outlet
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
9/30/2011 1:20:52 PM • Day-Timer... • Answered on Sep 30, 2011
I have a UTILITECH 1-
Yes you press down the bars for the length of time you want it on....
heatman101
11/3/2010 10:47:18 PM • Day-Timer... • Answered on Nov 03, 2010
I have a Lithonia dusk to dawn flood light that's brand new there's also an on off switch. What does the on off switch control and for dusk to dawn should it be on or off?
  • When the switch is ON, the light operates in dusk-to-dawn mode. In this mode, the light automatically turns on at sunset and turns off at sunrise. When the switch is off, the light stays off.
4/18/2024 7:13:42 PM • Hardware &... • Answered 22 hours ago
2answers
Grasslin QE7+ water heating timer dial problem
motor or gear failure
3/12/2024 10:39:33 AM • Hardware &... • Answered on Mar 12, 2024
Electrolux KOAAS31WX oven timer has maximum 20 minutes.
It sounds like the button contacts aren't making good contact. If you can get behind them you can spray them with electrical switch cleaner. ..
3/2/2024 6:36:01 AM • Hardware &... • Answered on Mar 02, 2024
How do I reset the ellis geyser timer to save electricity
Press P (program )on the timer and display will show then change the desired day, time and minute using the D+, H+ and M+ buttons. Press P again to set up another program and repeat the second step as above
2/26/2024 7:44:48 AM • Hardware &... • Answered on Feb 26, 2024
How do I program outdoor timer model 28486
Clear memory by pushing the reset button on the timer then reprogram using your current schedule when you want the timer to go off/on. Use the day and clock buttons for this then press enter
2/26/2024 7:35:43 AM • Hardware &... • Answered on Feb 26, 2024
Should the utiletech 24 hour manual timer make a humming noise while on?
No, the timer should not make any noise. The noise should be a result of loose connections which cause arcing, which can make a humming or buzzing sound. If you find that you still notice the sound, even when the main breaker is off then the problem is not electrical in nature.
2/26/2024 5:38:54 AM • Hardware &... • Answered on Feb 26, 2024
Micromark MM 9565 Timer. How to set up the timerMM9565micro Mark timer
Question edited for clarity and add a header in order with spaces and CAPS. It appears Micromark got out or the timer business. There is a similar one in another Fixya post, and a link to them. https://www.google.com/search?q=Micromark+MM+9565+timer ..
2/19/2024 10:55:33 PM • Hardware &... • Answered on Feb 19, 2024
Day-Timer Intermatic Ei600c Digital 7 Day Timer 20 Amp 24277v Logo
6 questions posted
Top Day-Timer Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Day-Timer Hardware and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Day-Timer Hardware & Accessories
Most Popular Question
lost instructions intermatic
  • Hardware & Accessories
