20 Most Recent
Kohler Fairfax Single Control Lavatory Faucet with Lever Handle Polished Questions & Answers
Kohler Fairfax kitchen faucet has
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
How do I remove the plastic insert to access the cartridge on a Kohler K-171 kitchen faucet?
To remove the plastic insert on your Kohler K-171 kitchen faucet, you can follow these steps:
First, turn off the water supply to the faucet.
Next, remove the handle of the faucet by unscrewing the set screw on the underside of the handle using a hex wrench or an Allen key.
Once the handle is removed, you should see a plastic insert that covers the cartridge. To remove this insert, use a flathead screwdriver to gently pry it off.
Once the plastic insert is removed, you should be able to access the cartridge.
If you need more detailed instructions, you can refer to the installation manual for your Kohler K-171 kitchen faucet .
Valve is set to far into the wall...
First, your not going to like the solution. There really is no way to solve this on kohler faucets. Some companies make adapters but as far as I know kohler isn't one of them. Hopefully you can cut a hole in the drywall behind and put it where it should be, if not the marble comes back off.
