20 Most Recent
Wilton 14in Woodmetal Cutting Band Saw Questions & Answers
Band saw is going in reverse how to i fix that
The motor is AC (alternating current) and only runs in one direction. Therefore, the only way to reverse the saw blade direction is to flip the position of the motor 180 degrees. The teeth of the blade should be pointing down and face to the left when you are standing in front of the saw. The blade should travel down into the table so the blade pushes the work into the table. I hope this helps since it sounds like the blade may be installed incorrectly.
Blade comes off wheel on horizontal saw
if its a new blade, make sure that it is the proper length for the saw, sometimes aftermarket blades look like they are the right size but the difference of a few mm can cause the blade to track. if its an old blade, it could just be dull enough that it is binding on the material you are cutting and this draws the blade off the wheels. even if the blade isnt that old or seems sharp, if you have a brand new blade handy that would be the easiest thing to try.
your manual will have instructions on how to adjust the blade guide bearings. if this is a new saw, it SHOULD be set properly and be working from the factory but they may still need to be adjusted. an older saw obviously may have shifted a bit from normal usage. if you dont have a manual one can be downloaded from the wilton tools website.
before adjusting the guides, though, check to see that the bearings spin freely. if they do not spin smoothly with minimum pressure, they need to be replaced. they also should be replaced if they spin VERY freely because this is also an indication that they are pretty worn and may actually be binding up under pressure.
12/4/2009 6:46:54 AM •
Wilton Saws
Answered
on Dec 04, 2009
Why my Makita disc cutter has spark wont start
If the fuel in it is 2 or more months old dump it out and put in fresh fuel and try statring. Also try try a squirt of starting fluid into the carb. If it fires on it you may need to do this a few times to pull the old fuel in the lines through till the fresh fuel can get to the carb.
4/10/2024 4:13:02 PM •
Saws
Answered
on Apr 10, 2024
