20 Most Recent
Husqvarna Tile Saw Tilematic Ts 250 X3 965154414 Questions & Answers
Where do I buy parts
i beleave target makes husqvarna try that 1st,if not try a tile store that sales saws,1st,try target tile saws i bet they will take care of you
Husqvarna K970 power cutter saw gas powered engine.
FIRST TIME EVER USED IT ? 6.5h ENGINE HERE.got spark, THIS IS FIRST, using fresh plug to test.got fuel? or is it super old fuel.canT burn gas , lacking spark , the engine may have compression release just like huge single cylinder motor cycles have, and can fail. but just harder to start failed.ASK MAKER FOR HELPTOP CAUSES (BY ACTUAL USAGE FAILURES)SO THIS TOOL SITS LONG TIME UNUSED? NOT TOLDBAD OLD FUEL AND FILTERS AND CARB. DIRTY.ENGINE IS 2CYCLE , GAS AND 40:1 OIL MIX OR PER MANUAL.FUEL FILTER PACKED, AIR FILTER PACKEDspark plug fouled, put in new. and gap it.and this.EASYSTART SYSTEM.The engine and starter are designed to ensure quick andeasy starting of the machine. Reduces the pull resistancein the starter cord by up to 40%. (Reduces thecompression during startingSEE PAGE 6https://www.lsengineers.co.uk/media/advice_centre/Husqvarna/Power-Cutters/operators-manual-k970.pdfSEE PARTS.
https://www.husqvarnaconstruction.com/us/power-cutters/k970/?article=967348001
Husqvarna partner 750 concrete saw wont start
You need to make sure it is mechanically sound, has the piston picked up on the exhaust side? does it have enough compression? is there signe of concrete dust on the inside of the air filter and filter houseing?there are many after market carb gasket sets, some have a small hole missing from the diaphram and gasket on the metering side, this activates the compensator, this needs to be there as the metering cover has no breather hole in it.
Not cutting
Please be more specific with your question.
