20 Most Recent
Magellan Meridian Color GPS Receiver Questions & Answers
Meridian color wil not power
Yes it is possible that sense you just changed batteries with out powering it off first through the computer off. Try to reboot it. Meaning make sure it is off of course, then as you power it on, keep the on button depressed through the whole turning on process, even 10 seconds past. Meaning, while it is turning on, you keep your power button depressed or switch on, through the whole process. If this does not work, take batteries out, wait about 15 minutes and try this again. What this does is manually reboot system. Let me know, Thanks Mike from fixya.
9/1/2011 3:29:01 PM •
Magellan...
Answered
on Sep 01, 2011
I'm trying to upload maps from mapsend bluenav
Call Magellan and tell them the web page you were dircted to has been removed tell them your license number and they will unlock a sd card when you give them the sd serial number I went through this two years ago.the link you need has been removed from there server
9/13/2010 1:45:01 AM •
Magellan...
Answered
on Sep 13, 2010
When i try to turn
Try reloading the firmware, its available on the Magellan website.
You may need some of the back door commands. There is wonderful trouble shooting information at
www.mtgc.org/robertlipe/MeridianFAQ/ start reading about page 12. If you need to reload the master maps, they are on your MapSend Streets disk. With the laters firmware update I can use a 1GB SD card but I have not been able to get a 2 GB card to work.
Magellan no longer supports this device, so contacting them is a waste of time, they are rude, stupid, and won't tell you anything even if they know it.
3/21/2009 4:25:29 PM •
Magellan...
Answered
on Mar 21, 2009
Magellan meridian color
Might I suggest buying the Lowrance Ifinder of any model that way it will work with all the software I have and I can keep it up to date :-P
Love,
Lonnie Levan
3/21/2009 4:13:42 PM •
Magellan...
Answered
on Mar 21, 2009
BlueNav sd problem ??
Problem solved. I took out the BlueNav sd and pressed the menu and power buttons at the same time. Afterwards I tried with BlueNav sd and everything is working fine.
11/17/2008 8:59:16 PM •
Magellan...
Answered
on Nov 17, 2008
yes i can help you. go to the magellangps site. up on top put your pointer on support and then choose legacy products. they list them buy the name of the magellan gps. i hope this helps you.
9/6/2008 1:16:51 AM •
Magellan...
Answered
on Sep 06, 2008
How To Resolve The Issue Of Magellan GPS Not Detected
Steps: Resolve The Issue Of Magellan GPS Not Detected
Well, what you need to do is to make sure that you switch off your device and then plug all the cables out. You need to wait like that at least a minute. After the minute is over, what you need to do is to make sure that all the plugged back in.
https://mapupdates.org/blog/magellan-gps-not-detected/
10/14/2022 9:49:46 AM •
Magellan GPS
Answered
on Oct 14, 2022
How do I Update Magellan GPS Device?
Magellan is an association which is delighted in giving GPS device to the usage of people. These device are trustworthy and they furthermore help the customers in taking off to any place with no issue. A customer ought to reliably keep the device invigorated for the courses and roads which makes it huge for the customers to perform Magellan GPS Update routinely. This moreover empowers the customers with the objective that they to don't slow down out in some spot or they don't face any kind of issue. While living in a hot world, we go over different issues in view of lacking information about spots and courses. Most of the issues happen when we make an outing beginning with one spot then onto the following and it is noteworthy for every person to take the help of the GPS device so they can go with no issue and don't get lost during traveling. To know how to update Magellan GPS please click on the given link:-
https://www.gpsupdatesupport.com/how-to-perform-magellan-gps-update/
9/28/2022 11:47:29 AM •
Magellan GPS
Answered
on Sep 28, 2022
How to set the time
TO SET TIME ON EXPLORIST 100 CLICK ON MENU CLICK ON PREFERENCES CLICK ON RESTART GPS SELECT YOUR COUNTRY CLICK ON YOUR STATE THEN SET TIME.
9/16/2022 11:37:14 AM •
Magellan GPS
Answered
on Sep 16, 2022
