20 Most Recent
Delta Laser Crosshairs Drill Press (17950L) Questions & Answers
I have a Delta 17-950L drill press. The table is
You don't want the table to be perfectly level, it does need to be perfectly perpendicular to the quill. If the motor housing or quill is not be perfectly straight up and down, as appears to be the case with your drill you will need to square the table to the quill, both left to right and front to back.
Is there a place I can get a manual for the Delta
yes, go to "dewaltservicenet.com" and type in your model number as you list it and you can download the manual. It is 18 pages long. If you need more assistance let me know and if I have helped you would you please vote accordingly. Thank you
7/18/2018 6:05:51 AM •
Delta Drills
Answered
on Jul 18, 2018
I need a new switch for a delta 11-960c drill press
My table saw switch quit working and I got the runaround in trying to get a replacement. What I ended up doing was fastening an electrical box over where the old switch was and installed a wall light switch like you have for a light in your house. This has worked about five years now with no trouble.
7/21/2017 3:30:28 PM •
Delta Drills
Answered
on Jul 21, 2017
Motor start capacitor
replace but something is to measure where the motor sucks on the start up bad armature bearings or is there a centrifugal cludge for startup inside thats not good timed or worn or its only because the capacitor is to old..
5/15/2016 11:28:40 AM •
Delta Drills
Answered
on May 15, 2016
How do i change the chuck on a delta drill press
it looks like it requires a special tool called a wedge, look on the side of the chuck for something like 1 or 2 , 3 jacobs taper and then the wedge would be accordingly, they come in from either side and you would hit them with a hammer to unseat the taper fit. Let me know if you need more assistance.
9/2/2014 11:05:46 PM •
Delta Drills
Answered
on Sep 02, 2014
