There is a filter screen on the pickup tube in the tank (or there should be) if there is a lot of debris in the tank it will slowly start to plug up the screen and reduce the liquid intake for the pump. If that is not the case then take the spray nasals off and clear the debris from them. Hope this helps you.
Sounds like a well pump with a leaky foot valve. I beleive you are correct in that it air lockes then when you shut it off the water flows back eliminiting the air lock.
you should check the foot valve that would be at the bottom of the well pipe the fasted way to check it is shut off the pump and see if the system pressure drops down
I could give more specific advice with a more accurate model number. shureflow's website does not have that exact model number. First, turn off power to the pump then try all the screws in the front for tightness. In general those type of diaphragm pumps have replacement parts that can be installed. I am assuming that the leak is from the pump not the fittings on the pump. if it is from the fittings reply and I will help you with that.
here is a PDF of a SIMILAR pump. before you order make sure you have the exact match for your pump. most of the kits run about $15 Here is a good place to look for parts. make sure the material you get is approved for drinking water, or for whatever chemical you are using. There are several types of materials the pumps can be made from and you will need to pick the right one
Also consider the age of the pump it may be a better option to just purchase a new one may be the way to go, especially if you don't want to, or feel comfortable taking the pump apart to replace parts.
There are also complete pump heads that can be purchased as a replacement.
Hope this helps you out
Hello;
Water water everywhere.... The pump you installed has no way of knowing when to stop. Shurflo also has a pump with a pressure switch that senses pressure drop to turn on and back pressure to stop. I'm sure the dealer that sold you the one you now have will have the proper modell for your application.. Good luck and be sure to put a filter in the line coming from the fresh water tank. You should be all set with this recommendation._Ned_
Question edited for correct spelling of maker 'Noen' to 'Moen'.
'Fix' as in it is leaking? Or tighten it down because it is wobbly, or something completely different?
Well, we can have a one on one seminar by the internet. I've been a pumpman for 20 years. I can share with you my experience (household pumps, suibmersible pumps, turbine pumps, gear pumps, piston pumps, dewatering pumps, mud pumps, trash pumps, mining pumps, solids handling pump, etc....) Just take your pick. Just send in your e-mail for assistance. God bless.
It is leaking due to a defective mechanical seal. It needs to be replaced. To replace it, is to take the pumpcase off by taking off the bolts that hold it. Then, take the impeller off to take the mechanical seal behind it. Put the replacement in, and reassemble the pump. Just get in touch with us by e-mail to get more assistance.
Move the lever or turn the knob. Check the stop tap under the sink. Make sure the faucet control knob or lever is tight, There is normally a removable cover that hides the screw..
