20 Most Recent
Campbell Hausfeld FP2095 2 Gallon Twinstack Air Compressor Questions & Answers
It runs but the pressure is not going upto 100psa
It could be a worn teflon piston if it's an oilless compressor, the loud noisy ones use no oil instead they use a special teflon piston/ring set witch has low friction other than the typical old cast iron piston compressor with an oil reservoir.
2 things, you may have a leak or stuck valve, or a hole in the tank, look and listen for leaks
Your piston is worn out, the teflon is worn or scored and air bypasses the side of the piston, you need a piston rebuild kit, they are around $ 30-40, easy to install in most cases. It may contain a piston and replaceable cylinder wall.
Good Luck
11/22/2016 6:50:40 PM •
Campbell...
Answered
on Nov 22, 2016
Campbell Hausfeld air gun has air coming from the nose tip and no nails
If air is coming out from the nose tip but the nailer is not firing any nails, it could indicate a problem with the driver blade or piston assembly. Check if the driver blade moves freely and is not damaged. Make sure the piston assembly is properly aligned and lubricated. Also, check the nail magazine to ensure that it is properly loaded and the nails are the correct size for the nailer. If the problem persists, it may be necessary to take the nailer to a professional for repair.
2/14/2023 2:59:32 AM •
Campbell...
Answered
on Feb 14, 2023
Need to know start cap specs for c1071080vmsa campbell air compressor
Kranson 3 Nov 03, 2022
I'm late to the party, BUT...
There's 2 ea of both start and run capacitors in this compressor...
Start: PN- 351052-53, 815-970 MFD, 165VAC
Run: PN- 175863-30, 30MFD, 370VAC
The section ^^ UP THERE ^^ is for asking the OP further information before committing to an answer down here. The question is now marked SOLVED and will show in Search. Thanks
11/3/2022 5:10:21 PM •
Campbell...
Answered
on Nov 03, 2022
Campbell hausfeld wont build pressure
The most probable are
Leak in air lines, bad valves, bad piston rings or o rings., bad check valve on tank, leaking unloader valve. Tou can google your model number and there will be more info.
10/30/2021 3:21:28 PM •
Campbell...
Answered
on Oct 30, 2021
Why does my campbell hausfeld 80 gallon 2 phase air compressor start to bog down at 90 psi
There is many reason for this simptome ,
could be running capacitor ,, Pressure switch dirty or it going bad,, Or ,If you meen lick choking and conteniu going could be also your check valve ,,,
If you can post a video I will help you better ,
I need to hear what it doing ,
9/8/2019 9:33:07 AM •
Campbell...
Answered
on Sep 08, 2019
