20 Most Recent
Blaupunkt MP3000 CD Player Questions & Answers
I have a fit punto
Good Day!
Please try code 7148
Don't forget to rate my answer.
Thanks for asking Fixya.
"how do i turn off the volume controlon my sterio
its the problem of your amplifier section voltage controller. Get it replaced else your might blow up the system .
And to disable volume control u have a rotary potentiometer underneath the face panel accessible by unscrewing the panel . just short circuit the two ends of the POT in order to get the volume control disabled . but this wont solve your present problem ..
I need the manual on how to set the radio stations
t
http://www.retrevo.com/support/Blaupunkt-MP3000-Car-Receivers-manual/id/550ci556/t/2/here is your manual....just click the red download button the fill in your email addy and the code and it will download for you. It is a pdf file so if it wont open you need adobe acrobat reader...d/l that and try again...
for the clock keep pressing disp till you see clock 12----then rotate the dial to select 12 or 24 hr format----then press disp to display clock adjust-------then press muts/sens to flash the hour-----rotate dial to desired hour-----press mute/sens to flash min-----rotate dial for correct min----press disp to complete the time set.
don't forget to give testimonial and the votes 4 thumbs up if I helped.
Hi thereI have a holden barina 2004 with a Blaupunkt 2020 radio.
Radio codes are unique to each vehicle and are typically provided by the vehicle manufacturer or the radio manufacturer. To obtain the code for your specific radio, you will need to contact a Holden dealership or a Blaupunkt authorized service center. They will be able to assist you in retrieving the correct radio code.
You may need to provide proof of ownership and the serial number of the radio (which you've already provided as BP248554092649 No 92 094 577). Once you have the correct code, follow the instructions in your owner's manual to enter it and unlock your radio.
Suzuki Ignis radio code
Hi I have suzuki ignis too and I have problem with radio code too...but I am from slovakia and my english is so amynous...and I dont understant this web side (
www.ukbookshelf.co.uk) its free ?
39101-86G1
ID: 39101-86G1.......like gedwards80 on the top :)
